Old 05-12-2019, 11:31 PM   #1
Peanut74
Order of rust repair
Ok, I got my cab media blasted and identified all the rusted areas. On the left side I need to replace a section of the floor, kick panel, lower pillar post, inner and outer rocker panels. The floor supports seem to be solid and I will confirm that once I open it up.
My question is what is the order I should use to replace the rusted parts?
> Run some 1" tubing braces and just cut it all out
> Replace the bad floor sections then the pillar and then the inner rockers
> Just the opposite the pillar and inner rocker and then the floor sections
For the outer rockers I will weld them in once I have the doors on. Just want to make sure that I don't get the cab out of alignment
Peanut74 is offline   Reply With Quote
