Old 05-13-2019, 08:51 AM   #1
Android04
Android04's Avatar
Bouncy Ride
Happy Monday C10 Family.
Just need a little advice here. I have a SWB C10 on air, I'm running Dominator D2600 bags all the way around. I originally was running some KYB with shock extenders in the rear but recently upgraded to the Belltech Street Performance Shocks 2104HA. Since the install it seems like my ride height is bouncy as all get out in the rear. I usually drive with about 30psi in the rear, and regardless of how much more air I put in it or take out it's still real rough.
So my questions; since these are drop shocks should I now remove the shock relocation kit and mount them back to factory location? Should I run a different shock in the rear? Suggestions? Thoughts?
Thanks,
-Andrew
Android04 is offline   Reply With Quote
Old 05-13-2019, 09:00 PM   #2
Overdriven
Re: Bouncy Ride
The only way to determine if the shocks are the proper length is to remove them and measure. Measure the shocks compressed and extended, then measure the shock mounting holes while aired out and at ride height. Btw you want the shock to be longer than your mount measurement at ride height. If the shock is bottoming out or fully extends this can create a harsh ride.
You might want to check into shocks from a vendor like NoLimit, PB or others. They might be more expensive but they’ve been tested and/or valved to the vendors specs. Air bags behave a little different from coil springs particularly on rebound
Overdriven is offline   Reply With Quote
Old 05-14-2019, 09:25 AM   #3
Android04
Android04's Avatar
Re: Bouncy Ride
Thank you overdriven, I will pull them off and measure them and go from there.
Old 05-15-2019, 09:46 AM   #4
PGSigns
PGSigns's Avatar
Re: Bouncy Ride
Better describe "ride height is bouncy as all get out" Is the height changing? Is it a stiff bounce? Have you just ran the shocks to full extension as you added more air? They are good shocks you just need to make sure as mentioned above you have the correct length.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 05-15-2019, 11:30 AM   #5
Android04
Android04's Avatar
Re: Bouncy Ride
Jimmy
Thanks for the reply PGSigns. While at ride height it is bouncy over large bumps, pot holes, speed bumps, etc. I have a feeling I'm running out of shock. So this weekend I plan to C-Notch my truck and then measure out the shocks and see if the relocation kit is causing them to run out. If that's the case then I'm going to move to the original shock location and remeasure and go from there.
Old 05-15-2019, 03:28 PM   #6
SCOTI
SCOTI's Avatar
Re: Bouncy Ride
What year truck?
What shock relocation 'kit'?
What are the shock lengths old vs. new? (Fully compressed; @ ride height; fully extended)
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
SCOTI is online now   Reply With Quote
Old 05-15-2019, 03:46 PM   #7
Android04
Android04's Avatar
Re: Bouncy Ride
Originally Posted by SCOTI View Post
What year truck?
1965
CPP Rear shock relocation kit
Compressed Length: 10.00"
Extended Length: 14.75"
(based on their website)
Old 05-15-2019, 05:19 PM   #8
SCOTI
SCOTI's Avatar
Re: Bouncy Ride
1965
Based on their provided specs, you need to measure them @ ride height & that should help determine a solution. With CPP, I would personally verify their specs are correct on the shocks.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 05-16-2019, 11:43 AM   #9
PGSigns
PGSigns's Avatar
Re: Bouncy Ride
The shock relocation kits are there to help improve the shock angle. Going back to the stock setup is just going to make that angle worse. In my 65 when I went to air i made brackets to put the top shock mounts behind the axle similar to the kit from No-Limit. It really does a good job of getting the shock where it can work well. http://nolimit.net/products#!/~/prod...32&id=26244502
Jimmy
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
