Old 05-13-2019, 10:01 PM   #1
23window
23window's Avatar
3 speed interchange question
Hello all,
After hours of internet research I have a handful of random information about transmissions that I'd like to clarify.
I want to put a 67-68ish 3 speed trans behind a 235 Chevy in a 55 sedan.
Can it be as simple as just finding a 67 Saginaw and bolting it up?
I was told the Muncie 318 behind the 235 could not be rebuilt due to obsolete parts.
Guidance and clarity would be appreciated.
I want to keep it as simple as possible so no 4-speeds or T5 swaps thanks.
23window is offline   Reply With Quote
Old 05-13-2019, 11:09 PM   #2
geezer#99
geezer#99's Avatar
Re: 3 speed interchange question
67-68 was an sm318 just like the one you have.
Here’s a link with some good info.
http://67-72chevytrucks.com/vboard/s...=414555&page=2
Old 05-13-2019, 11:33 PM   #3
23window
23window's Avatar
Great link,
I'll keep my eyes out for a good trans.
Old 05-13-2019, 11:37 PM   #4
geezer#99
geezer#99's Avatar
What obsolete parts do you need.
There are rebuild kits available.
https://www.ebay.com/itm/GMC-Chevy-M...ty!98225!US!-1
Old 05-14-2019, 12:04 AM   #5
23window
23window's Avatar
The second gear idler is supposedly not available new.
To be clear, in not a trans builder. I'd love to have my transmission rebuilt locally but I wanted to do my research before I pull the trans out.
Old 05-14-2019, 12:22 AM   #6
geezer#99
geezer#99's Avatar
Maybe these guys might have one or know where to find one.
http://www.garagemotorsports.com/muncie.htm
Old 05-14-2019, 06:06 AM   #7
My friend put a '72 C/10 Saginaw and rear in his '55 1st. I can pick his brain, but pretty sure it went right in and it took some effort to get the linkage right. Very road worthy... as in interstate hiways. I have driven it on long runs and it rolls right along smooth as silk. A bone stock truck other than those two components. Full synchro is nice
Old 05-14-2019, 03:37 PM   #8
weim55
A1 Transmissions here in Denver Colorado can completely rebuild your original ‘55 SM318. They have a complete stock of new and used parts for these transmissions and techs that know this old stuff really well.
Steve weim55 Colorado
weim55 is offline   Reply With Quote
Old 05-14-2019, 03:51 PM   #9
weim55
But to answer your original question : the 7 bolt Side to cover fully synchronized Saginaw three speed was used in various GM cars 65 and up and light duty trucks as the standard transmission from 69 up. The most important thing you will have to match is the input retainer diameter at the front of the transmission. This is the large 4 to 5 inch pilot hole in the bell housing. The seven bolt Saginaw has two different sizes for this. Measure your original 235 bell housing hole to match. Speedometer cable can attach to left or right depending on the transmission, another thing to match the same as your Original. The transmission output yolk Will have to be changed for the proper fine spline unit on your driveshaft and the driveshaft length may have to be changed as well. You will have to do some fabrication for the column shift linkage so make sure the arms are still attached on the transmission that you purchased, the arms from your original transmission are not the same. Other than that the transmission is a bolt in. It’s a significant upgrade from your original transmission, synchromesh first gear, smoother operation overall and quieter.
Old 05-14-2019, 09:12 PM   #10
23window
23window's Avatar
Perfect thanks much!!
