05-14-2019, 05:36 AM | #1 |
The Pits
I have little experience with body work and could use some advice for dealing with rust pitting. My cab, hood, and fenders, which are very straight, sat out for many years in an acidic environment. The surface rust has pits that don't sand out and I'm afraid if I keep at it, the metal will be very thin. Is there a prep or a process to take care of the rust in the pits so they don't come back?
Thanks |
05-14-2019, 07:58 AM | #2 |
Post Whore
Re: The Pits
sandblasting...there are some acids that will work as well..be sure to use epoxy primer on all bare metal...this would be answered better in paint and body section
Mongo...aka Greg RIP Dad RIP Jesse 1981 C30 LQ9 NV4500..http://67-72chevytrucks.com/vboard/s...d.php?t=753598 Mongos AD- LS3 TR6060...http://67-72chevytrucks.com/vboard/s...34#post8522334 Columbus..the 1957 IH 4x4...http://67-72chevytrucks.com/vboard/s...63#post8082563 2023 Chevy Z71..daily driver Last edited by mongocanfly; 05-14-2019 at 04:20 PM. |
05-14-2019, 12:57 PM | #3 |
Re: The Pits
Getting all the rust out of the pits as he suggested and high build primer and lots of block sanding. It's going to take some work but it will come out.
05-15-2019, 12:47 AM | #4 |
Re: The Pits
I'm not an expert, but I'm using Ospho to convert the rust in the deep pits. Then neutralize with water, clean with thinner, and prime.
Do some research on it. You'll get mixed reviews. Cheap enough, and I just picked up some at Ace Hardware today. If you look at Eastwoods "Afterblast" or POR's "Surface Prep", along with most rust converters, the active ingredient it Phosphoric Acid...Ospho. |
05-15-2019, 02:27 AM | #5 |
Re: The Pits
High-build primer will fill those pits.
1951 Chevy Panel Truck |
05-15-2019, 01:55 PM | #6 |
Re: The Pits
