05-14-2019, 07:36 AM | #1 |
Flip or shackle the rear down?!
Hi,
Looking at lowering my 74 long bed, but not sure of how to do the rear. Thinking djm 3” spindles in the front, then spring to suit. In the rear I was going to flip kit it, but I’m concerned I won’t have enough clearance without notching. I don’t want to notch, and I want to use the tub. Nothing crazy but occasional house Reno hauls. I have about 5 3/4” from the top of the spring to the bottom of the chassis rail. Axle tub is about 3”, so I’m guessing I’ll have about 2.5” clearance to the rail. What amount of clearance pre flip will allow me to not notch? Or am I better off just using the drop shakle hanger kit and dealing with it sitting heigher in the rear? Cheers! |
05-14-2019, 09:58 AM | #2 |
Re: Flip or shackle the rear down?!
Mine is not notched and is a 80 swb ,get the odd bottoming out on a big pot hole
05-14-2019, 10:53 AM | #3 |
How often will you haul something in the truck? The flip is a much better way than shackle method if you want 5/6inch or so drop. If the truck is empty most of thetime you should not have many issues without doing a c-notch.
05-14-2019, 04:52 PM | #4 |
Drove my truck from South Carolina, USA to central Maine, USA (1600 miles) with a flip kit and no c-notch, with about 150lbs in the bed and super worn out rear leafs.
Other than some terrible roads in one state (3-5" pot holes/cracks/lips in the middle of an interstate while going 80ish mph to keep up with traffic,) I didn't really run into an issue with the axle hitting the frame - I'll probably put an add-a-leaf to adjust the height and stiffen up the rear a bit but its more for appearance than function. |
05-14-2019, 09:45 PM | #5 |
I'm probably not going to be hauling a lot of cargo, mostly short trips with things like engines, rail way sleepers (the wooden logs), etc. However there might be the occasional long trip with a tray full of car parts for a swap meet. or maybe pulling a car on a trailer.
I'm just concerned that 2.5" estimated clearance will not be enough. what clearance are you guys running without a C-notch? You have a fair point about adding leaves, helpers or searching the springs tho if it is too low... |
05-15-2019, 08:04 AM | #6 |
Could always do softer springs and helper bags for load capacity
Big Nate Carp. Local 224. Buy made in the USA! 03 F350 6.0 Daily Race Truck. 79 C70 366 Project Dump. |
05-15-2019, 09:58 AM | #7 |
I hauled some fairly heavy stuff 400 miles with little bottoming out,mostly when the road dips here and there, you just have to get the weight off the rearend, put the heavy stuff right up to the cab.
05-15-2019, 12:13 PM | #8 | |
05-16-2019, 12:04 AM | #9 | |
Helper bags of load springs might be the way if its an issue... hmmm. |
05-16-2019, 10:22 AM | #10 |
I set-up my stuff for 3" of compression travel. 2.5" will prob be fine for 90% of the time but that's w/o a load. What's the clearance going to be when loaded? That's where a small notch might be beneficial.
05-16-2019, 08:33 PM | #11 |
I have a flip kit, no notches... there is lots of room as long at you take out the gigantic bump stops. I have never bottomed out and carried loads of 2-300lbs.
There is more than 2.5 inches clearance, I have almost 4" with the original 2wd springs (unloaded).
Frank (Hilo, Hawaii) Trucks, Tacos, and Beer go together like Peanut Butter and Ladies! 85 C/10 SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=760383 67 C/10 SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=489298 79 K5 Blazer SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=657461 |
