air ride question
i have air ride from bcfab on my 70 c10. i need to run 10lbs less air in the right rear than the left to make the truck set level. this is with the truck empty. anyone have any ideas what would cause this?
72 C10 6.0L 4L80E |
![]() Join Date: May 2011
Re: air ride question
Do you have an aftermarket panhard Rod? If you have a lowered suspension and a factory panhard rod it will pull on the rear suspension making the rear axle not centered under the truck and can also lead to the bed/frame not sitting level.
69 GMC C10 build thread- http://67-72chevytrucks.com/vboard/s...d.php?t=501676 03 Silverado build thread-http://67-72chevytrucks.com/vboard/s...d.php?t=591582 |
I have the long one from cpp
72 C10 6.0L 4L80E |
What air-ride set-up from BC Fab? What are the particulars?
What type of air management system?
Airlift 2600 bags
Avs electric valves Avs 7 switch control box 480c compressors
72 C10 6.0L 4L80E |
Was the air suspension just installed? Any other service work or suspension mods done prior to the 'air ride' install?
Shocks relocated
No other work It has been like that since I installed air ride Thanks
72 C10 6.0L 4L80E |
#8 | |
Re-check & see if the issue persists. FWIW, my dually has diff pressures @ all 4 corners & even that varies depending on temps.
![]() Join Date: Nov 2015
Could just be your gauge.
Measure RH with you sitting in the truck
Is the issue just that the pressures are different. The psi difference wont matter if you achieve the desired outcome..
