05-14-2019, 05:35 PM | #1 |
torque thrust ll 15x10 on step side
im having my 12 bolt rebuilt with new axles with 5x5 lugs.
does anyone know if the torque thrust ll 15 x 10 with 3.75 backspacing will fit a 1966 c10 stepside? im sticking with drums on the rear, so the rear end measurements are stock. If they fit, are 15 x 8 okay in the front? thanks in advance for your help. almost forgot to mention that the spindles have a 2.5" drop front and 4" drop in the rear. kevin |
05-14-2019, 09:16 PM | #2 |
But Found Her 25yrs Later!
Re: torque thrust ll 15x10 on step side
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 |
05-14-2019, 11:47 PM | #3 |
60-66 Nut
Fitment is going to depend on tire size and ride height at the rear. On the front, with the dropped spindle, the wheel may or may not have interference with the LCA. It depends on the backspacing
