long bed to short bed
I have a 72 chevy long bed, putting 67 clip on, ant to change to 75 short bed box. I want to keep 72 frame ( disc brakes, cleaned and rebuilt front end). How much do I need to shorten frame? any otheer parts needed?(beside driveshaft)
Did you really mean '75 short bed??? Please say you meant '67 (with no sidemarkers).
1972 C20 Suburban- Big Blue Betty '56 Chevy Bel Air Sedan- Frame up Restoration -What would you attempt to achieve if you knew you could not fail?- -I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door- R.I.P. EAST SIDE LOW LIFE |
nope - definately a 75 stepside, getting it for free and has new wood kit will probably change to 67 fenders
72 c-10 81 c-30 67 c-10 just sittin in the woods) 70 C-10 " " " " to compleete frames 67, 70 - in woods 2002 toyota tundra. 12 yr old son has , 72 Charger, 78 Ramcharger and 85 ford wrecker |
i love summertime
sounds like a plan, i think that there are some hurdles to jump swapping fenders besides the obvious though...
1967 shortbox stepside Chevy, 365 hp 327, th400. GLOVE BOX LIGHTS FORSALE, click link for info http://67-72chevytrucks.com/vboard/s...d.php?t=273724 |
![]() Join Date: Dec 1999
ive made the cut. its 12" from under the cab, no where else is straight enough to trust. then about 5-6" off the end of the frame. theres a company in oregon that sells a reinforcement kit specially made for our trucks for these projects. i also have quite a few pics of the job if you want
Current owner of 2016 2500 Silverado Midnight Edition. Former owner of: 69 1/2 ton, change from long/fleet to short/fleet, shaved door handles, shaved tailgate, 4/6 drop, power windows, 700r4 72 blazer, 350 with Holley Commander 950 DFI, crane energizer cam, 350 tranny, dual sanderson blockhuggers/magnaflow exhaust Last edited by gabet40; 11-28-2003 at 06:56 PM. |
it`s actually 8 " from the rear of the frame. look in custom classic trucks in the april 03 issue. early classics did the conversion and it gives a good step by step. i was going to do the same to my 68 lwb but i just found a swb frame for $100.
Anthony |
its all about the +6 inches
Isn't the 75 bed a little longer than the 67-72 beds? IOf so, this may chainge the amount chopped from the frame.
Saving 1 truck at a time!
'67 and '77 are identical...80 inches long. As far as I can tell the tailgates and bed front as well as the supports are identical. I would not put the later model fenders on however...they just don't match the smooth lines of the '67 - '72. I have seen them and they are clearly a design mismatch. Just my 0.02 however...it's your truck!
'68 C20 Longhorn 50th Anniversary 400/TH400 '68 C20 Longhorn 50th Anniversary 468/TH400w/buckets '72 C20 Halfhorn (Longhorn w/o cab and front clip) '69 Flxible Cruiser (look up ugly in the dictionary) |
i just talked to my buddy, he had a 75 swb and bought a 68 step bed to put on it and he said nothing lined up to mount it. just wanted to pass it on, maybe it will work, maybe it won`t.
Anthony |
