Old 05-15-2019, 12:12 PM   #1
73gmc1082
Can i use this intake with this rusty surface?with gasket sealer?(pic inside)
Hi i have a question the only intake i can find at a wrecker in my province without spending like 400 on a edelbrock was this one,i have been searching with no luck for a replacement,,, it has some rust/pitting issues on the surface under the egr side, i was wondering if i clean it up real nice with a very fine grit sandpaper and then use that permatex ultra copper max temp gasket sealer thats good for like 600f with a putty knife and fill in the divits,this engine uses a metal valley pan instead of 2 long gaskets, if i make it flush it should seal until i find a replacement later on? any thoughts or opinions would be greatly valued,* i understand i should replace it, but do you think my divit fill in would do the trick for now? other side is shiny smooth)
thankyou for taking a look
73gmc1082 is offline   Reply With Quote
Old 05-15-2019, 12:26 PM   #2
Bandit130
Bandit130's Avatar
Re: Can i use this intake with this rusty surface?with gasket sealer?(pic inside)
1974 Cheyenne 10 LWB Stock 350 W/HEI /TH350/AC/4 BBL Quadrajet
Mopar by Birth
Chevy by Choice
Bandit130 is offline   Reply With Quote
Old 05-15-2019, 12:38 PM   #3
geezer#99
geezer#99's Avatar
Spring time in Saskatchewan, yet!
Don’t bother filling it. Use some right stuff sealer on both sides of the pan and bolt it on.
Do me a favour!
Say howdy to my relatives for me!
My dad was born in Cupar
Old 05-15-2019, 02:46 PM   #4
Dead Parrot
2nd skipping the sanding. Instead use a wire brush(hand or drill powered) to clean most of the rust out of the pits. That way, the sealer will do a better job of sealing.
Dead Parrot is offline   Reply With Quote
Old 05-15-2019, 05:17 PM   #5
73gmc1082
ok so i did some work on it and this is what i have now, i was suggested to fill in with jb weld the pits and sand level, i was thinking just that high temp copper permatex to fill them in and let it set so it has some flat sealing cusion if i could get opinions after i sanded and worked it a bit.
the other side came out great, i didnt really want to work that spot too much and take too much off of it so im hoping it will seal, but this is what it looks like after, i dont feel as stressed using it as a temp for now just as long as i get those divots sealed,lol
* sorry if the pics big*
Old 05-15-2019, 05:46 PM   #6
geezer#99
geezer#99's Avatar
You’re over thinking it.
I’ve seen worse that sealed up with a smear of form a gasket.
Old 05-17-2019, 10:22 AM   #7
stanski
I've seen worse, but if you feel uncertain a machine shop can resurface those surfaces in a minute.
Go Riders! (but we need a qback)
stanski is offline   Reply With Quote
Old 05-17-2019, 08:00 PM   #8
Redneck Rydes
Redneck Rydes's Avatar
Just add some RTV and slap ot on
Redneck Rydes is offline   Reply With Quote
Old 05-18-2019, 09:54 AM   #9
frenchy51
frenchy51's Avatar
I second the RTV-It will be fine.
1972 Highlander PAC B 400BB-SOLD
1974 K5 Blazer-6.0 swap
1974 C20 Long Bed 454
1977 GMC HeavyHalf
several adopted orphans
frenchy51 is offline   Reply With Quote
