Old 05-15-2019, 12:43 PM   #1
keg
transmission shift problem
87 Silverado 350 4 speed auto. After replacing the trans filter and fluid it takes longer to shift and shifts hard most noticeable from 1st to 2nd. The only thing I did was change fluid and filter, or is there something I may have done or not done that caused this change in the shifting?
keg is offline   Reply With Quote
Old 05-15-2019, 03:28 PM   #2
Matt Man
Matt Man's Avatar
Re: transmission shift problem
How was the fluid you drained originally? Was it dark with metal flakes? A lot of times transmission fluid that has not been changed in a while or is in poor condition is actually whats making your transmission still shift good. You most likely have a 700r4 which is not a good transmission in stock form. I would check to make sure the fluid is at the proper level.
86 c30 crew cab dually 454/400 4/6 drop SOLD 1-8-11
1981 chevy K10 short Bed Scottsdale SOLD 10-26-2020
67 GMC Stepside Straight six/3 on the tree "The Peach"
2020 Silverado Double Cab LT Z71 5.3 8 speed Daily Driver
K10 build http://67-72chevytrucks.com/vboard/s...d.php?t=671934
The Peach build http://67-72chevytrucks.com/vboard/s...d.php?t=733903
Matt Man is offline   Reply With Quote
Old 05-15-2019, 04:52 PM   #3
keg
If the old fluid had any metal in it, it was minor and not obvious to me. The fluid level is correct. Shifted fine prior to the fluid and filter change. No problems with the transmission just PM
