05-15-2019, 10:45 PM | #1 |
Tightened the ol' girl up and got her off the ragjoint!
Made the XJ shaft swap tonight. Local search yeided a big fat zero so I bought one off eBay for $40. Propane torched the plastic inserts out, cleaned it up and painted with oil based enamel. Pretty straight forward install. Hardest part was notching the steering column stub for the pinch bolt. Very happy with the results. One of the best bang for the buck mods.
05-16-2019, 05:31 PM | #2 |
Re: Tightened the ol' girl up and got her off the ragjoint!
Nice work! It really does help tighten up things. I did the same but found one at the junkyard....
- Jeff 89' K5 Blazer, 2.5" lift, 35" tires 04' GMC Yukon XL, 3/4 ton, 8.1L |
05-16-2019, 07:33 PM | #3 |
Post Whore
looks great!
05-16-2019, 08:28 PM | #4 |
Hey, this is awesome, my girl is hooked on the ragjoint too... is that just straight off a Jeep XJ? Any particular year? Direct fit? I need more details? Part #?
Frank (Hilo, Hawaii) Trucks, Tacos, and Beer go together like Peanut Butter and Ladies! 85 C/10 SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=760383 67 C/10 SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=489298 79 K5 Blazer SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=657461 |
05-16-2019, 08:58 PM | #5 |
with the nylons out there will be slop in the D-shaft over time .
lots of guys drill 2 holes for a 5/16" hole and weld on a nut each . then set screw in the hole to hold it tight . if in a accident the shaft will still slide over the set screws to save you as there is no hole in the solid shaft just the outer D-shaft body . otherwise there a super upgrade for cheeper than the name brand and just as good .
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. |
05-17-2019, 11:29 PM | #6 |
And if anyone is wondering why the red, it's a carryover of my years of working on experimentel military aircraft and weapons. Any non-original part is painted orange for quick identification. It helps me and any future owner see what's been modified. It's just a quirk of mine.
05-18-2019, 07:05 AM | #7 | ||
It only has original paint once |
