Old 05-16-2019, 08:16 AM   #1
Afirehawk1
Brake Pedal Push Rod Suggestions
looking for the best option. i installed an 8-inch power booster and need the rod from there to the brake assembly.
Afirehawk1 is offline   Reply With Quote
Old 05-16-2019, 11:26 AM   #2
PGSigns
PGSigns's Avatar
Re: Brake Pedal Push Rod Suggestions
Most folks just lengthen the stock rod. If you go to the FAQ section under the part on power brakes there are lots of info on how folks have done it. There are also threads on drilling the mounting hole on the pedal 1" lower to improve the ratio.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 05-17-2019, 12:43 AM   #3
64shortbox
64shortbox's Avatar
Here's a couple of possibility's
https://www.speedwaymotors.com/Unive...Long,9330.html
https://www.speedwaymotors.com/Wilwo...it,136383.html
https://www.speedwaymotors.com/Speed...od,296871.html
https://www.speedwaymotors.com/Forge...-Rod,1539.html
https://www.speedwaymotors.com/Unive...Heim,9329.html
64shortbox is offline   Reply With Quote
Old 05-17-2019, 12:52 AM   #4
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Jimmy
I did this...
66 C20 Service Truck:
Old 05-17-2019, 09:09 AM   #5
verdell
verdell's Avatar
I just recently replaced the MC/booster assembly on my brother's '65. I made sure to order a unit that had the adjustable rod included and relocated the hole like other's have mentioned. On a couple of others, the existing rod was modified.
verdell is offline   Reply With Quote
Old 05-22-2019, 11:05 AM   #6
raidmagic
raidmagic's Avatar
Jimmy
hmmmm, I missed this step. 1" lower? What kind of difference does it make? If you push the MC all the way is it just for a better pedal feel?
raidmagic is offline   Reply With Quote
Old 05-22-2019, 01:06 PM   #7
The Rocknrod
Moderator
The Rocknrod's Avatar
It usually fixes a pedal ratio problem - read this: https://techtalk.mpbrakes.com/brake-...rd-brake-pedal
and/or this: https://techtalk.mpbrakes.com/how-to...ng-pedal-ratio
Old 05-23-2019, 09:36 PM   #8
raidmagic
raidmagic's Avatar
Originally Posted by The Rocknrod View Post
Thanks.
