Sbc starter
Hi folks good morning.
I just rebuilt an engine, I think I”ll need a new street performance starter. Do you have suggestions? Posted via Mobile Device |
At the body shop.
Re: Sbc starter
Have 3 of these on my fleet.
ACDelco 337-1011 Professional Starter https://www.amazon.com/dp/B007QBSX5A..._Yez3Cb50N41WQ
" That didnt make it any newer " " Dont antique the equipment " |
Thank you KQQL.
I think I could find it at NAPA local stores. |
Re: Sbc starter
If not, I”ll order from amazon
Thanks |
At the body shop.
Re: Sbc starter
Friend at the starter rebuilder in town says he cant buy them for the Amazon price.
![]() Join Date: Oct 2014
Re: Sbc starter
I used one of these on my 350. works great
https://www.dbelectrical.com/product...sdr0031-l.html
Phil "Money is only a tool to create and achieve what you want most in life" PayPal: rodnrudy@comcast.net |
#7 | |
Re: Sbc starter
Re: Sbc starter
Thanks guys!!!
I just ordered |
Re: Sbc starter
A Tilton mini starter is a great item
![]() 1940 Ford Dlx Coupe 1969 Mach1 |
![]() Join Date: Apr 2016
Re: Sbc starter
For the ACDelco mini starters like that, what is the correct thing to do regarding bolting it to the engine? I had a mini starter once for a couple of months, and had the wrong bolts, didn't know what bolts to get, couldn't not figure out the shimming, and ended up chewing up my flex plate, replaced the flex plate and put the original big starter back in with its original bolts. I understand there are supposed to be special bolts to use with an unthreaded portion that goes into the block. So, I'm interested in knowing the exact right thing to do, for example, part numbers on bolts, do we use washers or lock washers, thread locker, or what all is needed?
![]() Join Date: Nov 2006
Re: Sbc starter
Get a vette hi-torque 1969-1970 lt-1 reman, trade your old one in for core. Stay away from them gear reduction / china junk
I BELIEVE IN JOHN 3:16 |
Re: Sbc starter
Heh, I tend to agree w/ post 11 and would suggest that people learn the tiniest bit of electrical theory, then fix the messed up wiring in the vehicle.
#13 | |
Re: Sbc starter
#14 |
Re: Sbc starter
that's not hi-torque
#15 |
Re: Sbc starter
Ok
Cancelled!! |
#16 |
Re: Sbc starter
want me to get you a part number
#17 |
Re: Sbc starter
Yes thank you
#18 |
Re: Sbc starter
I just bought 1 from advance auto. $81.99 / ac delco number 3962253. 1970 corvette hp
#19 |
At the body shop.
Re: Sbc starter
I linked the wrong p-n
337-1022 ac delco $100 usually from Amazon. 678-107 Dorman x2 Gear reduction will outperform a direct drive at half the amp load.
