Reverse Light wiring question
I am in the middle of my rewire of my 1965 that did not come with reverse/backup lights. I am thinking about installing a set...but have a couple of questions.
I am installing a Tremec T56 Magnum 6 speed. It has a 2 wire pigtail wiring harness for backup lights. In my head, all I need to do is wire the backup lights to the pigtail..(one to the backup lights and one to a hot wire) so when I go in reverse the switch inside tells the transmission that it is in reverse and that the backup lights to come on...Am I thinking correctly? Last edited by roll_the_dice; 05-16-2019 at 02:26 PM. |
hillbilly
Re: Reverse Light installation
Yes. That will work. Make sure you put a fuse inline before the switch
-1962 C-10 |
When I had my T5, I took the factory hot wire for the reverse lights (factory option on my 66) and ran that to the switch and ran the other wire to the reverse lights, I think. I haven't had them working yet and wanted to redo the wiring with my T56 in hopes that I have working reverse lights.
Your option sounds much more simple! |
#4 | ||
hillbilly
I would say a 15amp would be plenty.
-1962 C-10 |
