11-28-2003, 05:46 PM | #1 |
Need help with Brake/turn lights
Ok, I got tail lights, but no Brake or Turn signal in the back
Any ideas
With a 1972 Chevy Custom-10 Long bed w/350cid th350, (under-construction). Progress on truck so far (follow link): http://67-72chevytrucks.com/vboard/s...ad.php?t=51051 and stage 2 http://67-72chevytrucks.com/vboard/s...ad.php?t=58132 ~ "Why couldn't you have just put the bunny back in the box?" ~ |
11-28-2003, 05:54 PM | #2 |
Inline 69
fuse
11-28-2003, 06:02 PM | #3 |
its all about the +6 inches
If not a fuse, probably turn signal switch.
Forget about the grounds...99.999% chance that is will NOT be the ground. You have checked the bulbs already though, yes? |
11-28-2003, 06:42 PM | #4 |
Ok, update........
Fuses are good, checked them ALL in the fuse block. I have Front Turn signals and on the inside. The bubls i will check but could i loose both bulbs at the same time?
11-28-2003, 06:47 PM | #5 |
Got flashers in the back?
11-28-2003, 09:57 PM | #6 |
Didnt check the flashers, But did not, they were not working either.
Took off lens covers and checked Bulbs.............What ya know, both blown I guess when the Volt Reg went tout it Fried them Thanks Lonhorn man, Jeff 5150, 67 sss U guys
11-28-2003, 11:24 PM | #7 |
Even though it seems stupid to double check them...I always do.
Proved the boss man wrong at the shop last week on this. |
