Old 05-18-2019, 05:58 PM   #1
HeavyHauler
Is entire metal dash frame removable on 1967-72 Chevy C10
Can the entire metal dash frame be removed on a 1968 Chevy c10 shortbed? I am planning a extensive restoration and was just wondering if the whole unit can be removed or is just the gauge panel and other accessories can only be removed.
HeavyHauler is offline   Reply With Quote
Old 05-18-2019, 07:20 PM   #2
72c20customcamper
72c20customcamper's Avatar
Re: Is entire metal dash frame removable on 1967-72 Chevy C10
Not to hard few bolts and the pinch welds at the cowel/ windshield.
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
Old 05-18-2019, 07:26 PM   #3
68Gold/white
There's 2 bolts on each side, that's easy. The front is spot welded to the windshield mount surface...windshield has to come out...not so easy...
Just trying to be specific about what Mark stated...
68Gold/white is offline   Reply With Quote
Old 05-18-2019, 07:36 PM   #4
LockDoc
The Older Generation
LockDoc's Avatar
And to expand on what those guys both said, there are 34 spot welds to drill...
LockDoc
Leon
Old 05-18-2019, 08:01 PM   #5
typerr
LockDoc
Ha! only 34 spot welds! Last time I was at Brothers Truck they were touting their new dash replacement panel with the a/c holes pre drilled and I thought "Hmm, I wonder how much work that is when I get ready to install a/c..."
typerr is offline   Reply With Quote
Old 05-18-2019, 08:05 PM   #6
LockDoc
LockDoc's Avatar
Most guys cut across the slotted holes under the dash pad and replace it that way. Still takes some work but not near as much.
LockDoc
Leon
Old 05-18-2019, 08:30 PM   #7
Grumpy old man
Grumpy old man's Avatar
they come out fast .
1967 Factory short bed - Old school
'71 - 350 / 4bolt / 487 heads / Edelbrock C3BX
Muncie M-22 4 speed / Hurst Comp plus
Factory 12 bolt posi 3.73 / 255-70-15
Smoothed firewall / Factory cowl induction
Power disc brakes / power steering / 3.5-5" drop
Grumpy old man is offline   Reply With Quote
Old 05-18-2019, 09:54 PM   #8
HeavyHauler
Hmmm...I wasnt wanting to cut the dash frame out. I thought it might just be bolted in. But its good to know what it takes.
