Old 05-18-2019, 06:01 PM   #1
HeavyHauler
Anybody try to straighten a bent tailgate?
All the tailgates that I have looked at for a 1968 Chevy C10 have been bent or curved. Is there a way to straighten a old tailgate or is it even worth it as it may not be as strong afterwards once it has been bent.
Maybe just buy a new one. I like the idea of finding a good original but I dont think that exists or are very rare.
HeavyHauler is offline   Reply With Quote
Old 05-18-2019, 06:17 PM   #2
notsolo
notsolo's Avatar
Re: Anybody try to straighten a bent tailgate?
Not an easy fix, I think you have to peel off the front. Remove spot welds and straitened out the pieces and put back together. I wasted a lot of time trying to slide flat bars and pull, clamp and reshape. It doesn't work. Clean take offs, from a camper could run... $900.
notsolo is offline   Reply With Quote
Old 05-18-2019, 06:56 PM   #3
HeavyHauler
Yep that is what I thought. Best to just buy a new one.
Old 05-18-2019, 07:54 PM   #4
LockDoc
The Older Generation
LockDoc's Avatar
You might read through this thread.
http://67-72chevytrucks.com/vboard/s...d.php?t=578233
There are a few more if you type straighten tailgate or flatten tailgate into the Google search box at the top of this page, click on the circle in front of 67-72chevytrucks.com, and click on the GOOGLE button.....
LockDoc
Leon
Old 05-18-2019, 08:13 PM   #5
68Gold/white
It's not impossible to straighten a tail gate, just not easy. I have friends that can DO anything. I do have one that needs to be split apart and massaged...I'm not scared...
There's still many good used units around. Become a paying member and post a "Want to buy ad".
68Gold/white is offline   Reply With Quote
Old 05-18-2019, 08:22 PM   #6
Grumpy old man
Grumpy old man's Avatar
fast and easy ...
https://www.youtube.com/watch?v=pGVTYpYPz9E
1967 Factory short bed - Old school
'71 - 350 / 4bolt / 487 heads / Edelbrock C3BX
Muncie M-22 4 speed / Hurst Comp plus
Factory 12 bolt posi 3.73 / 255-70-15
Smoothed firewall / Factory cowl induction
Power disc brakes / power steering / 3.5-5" drop
Grumpy old man is offline   Reply With Quote
Old 05-18-2019, 08:29 PM   #7
flashed
What a waste .
flashed is offline   Reply With Quote
Old 05-19-2019, 01:36 PM   #8
RTHarvey
That is odd. I'm pretty sure that a running Chevy pickup of that vintage will bring at least a thousand dollars around here, no matter how bad it is.
RTHarvey is offline   Reply With Quote
Old 05-19-2019, 03:07 PM   #9
rjs53
Nothing bringing that truck back. Back to the subject at hand, could you tack allthread to it then run a piece of Chanel along those to draw it back straight.
2003 Dodge 2500
1969 C10
2014 Camaro SS/RS/1LE
rjs53 is offline   Reply With Quote
Old 05-20-2019, 09:28 PM   #10
KY_GMC
KY_GMC's Avatar
I've fixed a tailgate that was pushed in from the outside, but not fixed a bent one.
The tailgate looked like it was hit from the outside and pushed where the letter M is.
I drilled out the spot welds on the sides and across the bottom and cut across where a bend was. This made it easier to hide the weld seam. Then it was easier to straightened out the bend area. Then just welded it back together, one spot at a time.
It was a lot easier than trying to bend it back while it was still in one piece or trying to pull the panel out with a stud puller.
I think it turned out pretty good. I liked the idea of using and original tailgate instead of a repop.
1972 GMC 1500 Super Custom, 383 Stoker, TH350
Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=592157
Engine Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=592233
KY_GMC is offline   Reply With Quote
Old 05-21-2019, 12:41 AM   #11
rjs53
Looks great! Guess a guy could do the same on the inside.
2003 Dodge 2500
1969 C10
Old 05-21-2019, 07:12 AM   #12
A1971Blazer
A1971Blazer's Avatar
I was never able to straighten a bent one.....but I have bent a lot of straight ones...
1967 C10 Step side
1968 C10 Step side
1970 Chevrolet K/5 Blazer
1972 Chevrolet K/5 Blazer
A1971Blazer is offline   Reply With Quote
