05-18-2019, 08:31 PM | #1 |
NV4500 swap 1987
Has anyone done a SM465 to a NV4500 swap recently ? I am currently doing this on my 1987 K30. Most of it is going well and the trans. mount and drive lines fit perfect. I had a question on the studs that A.A. supplied with the spacer. I believe I read somewhere that they were too long. Anyone have any info ? Thank you
Bill @ Vintage Chevy Trucks |
05-18-2019, 08:35 PM | #2 |
Post Whore
Re: NV4500 swap 1987
are you referring to the transfer case adapter?
05-18-2019, 09:58 PM | #3 |
Yes I am. I have the spacer that is about 1 3/4 to 2" thick. They included all thread studs. After I posted this, I took a small pick and checked all 6 holes. 5 of them have a bottom, one goes into the case. I'll have to be careful not to let it screw in to deep and I will match the others. Now the problem is the spacer is not an easy fit on to the front of my 205. I am sanding it smooth right now.
05-19-2019, 11:33 AM | #4 |
i used red thread locker on the all thread / studs to help hold them in the case .
as much as they get for there crap you would think we would be getting real studs by now . even with the spacer you need to cut a chunk out of the nv4500 adapter to clear the shift rail and linkage . pic looking down at the case from up in the cab .
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. |
05-19-2019, 12:00 PM | #5 |
I put the spacer on and I'm thinking that they really need to do some more engineering on it. I will have a friend that owns a machine shop around the corner, clean this up for me before installing. I have already cut and trimmed the end of my NV4500 where it meets this adapter. I also extended the Transfer case lever bracket and made a L shape on the end. It fits perfectly with bolt hole at about 2:00 position.
05-19-2019, 12:03 PM | #6 |
What year 205 do you have. The newer style (86-87) take a different spacer /ring. Mine has the 6 bolt, round front.
05-19-2019, 01:24 PM | #7 |
my friends was the 6 bolt round setup .
we used a offroad design twin stick kit . if you have not make a 2 bolt tab that pickup the 2 bolts for the tail adapter to main case to help triangulate the shifter lever setup bracket . unless you picked up other bolt holes further up the side of the case .
05-19-2019, 03:11 PM | #8 |
I wished I had a working tranny jack. That must have helped. I used my forklift with a pallet strapped to the end of my forks. It actually worked nicely.
05-19-2019, 05:20 PM | #9 |
i use the Trans jack for gas tanks / trans / t-cases / support axles when doing suspension work / all sorts of stuff . this one is almost like a GREY automotive unit but 400 bucks cheaper . i know were the cheaper is ...... the table and its adjustment points are sloppy compared to a GREY unit .
05-19-2019, 05:39 PM | #10 | |
05-19-2019, 05:41 PM | #11 |
MacGyver would have been proud of me and my engineering.
