Old 05-19-2019, 01:27 PM   #1
randy500
Wiring harness, under dash with gauges type, very clean.
Had a scotch lock wire tap on the brake wire for brake controller, I installed heat shrink to repair it.
These are very hard to find this clean.
$140 shipped.
randy500 is offline   Reply With Quote
Old 05-20-2019, 07:55 AM   #2
bestchevyfan
Re: Wiring harness, under dash with gauges type, very clean.
Is this for factory a/c also.i have a 1967 chev cab with factory a/c.it has no under dash wiring harness .i need one [mint] thanks,buddy
bestchevyfan is offline   Reply With Quote
Old 05-20-2019, 09:15 AM   #3
randy500
It’s a long answer....
AC is a separate harness that connects to the standard under dash harness. The connection is to the larger brown wire in center left of picture 1, where it’s in a connector with orange and yellow wires.
67-8 under dash wiring harnesses are different in basically one way, the fuse box mounts higher up the firewall and is horizontal vs vertical. THe 67+8 fuse box is different shape too.
This one is not a direct bolt in.
Old 05-20-2019, 01:19 PM   #4
jimer1964
jimer1964's Avatar
So what year is it from?
jimer1964 is offline   Reply With Quote
Old 05-20-2019, 01:33 PM   #5
randy500
Originally Posted by jimer1964 View Post
so what year is it from?
1972
Old 05-20-2019, 01:37 PM   #6
randy500
Inside harnesses are for with or without gauges and for 4 speed or auto/3 speed manual trans.
This is for gauges with auto/3 speed manual trans and fits 69-72
Old 05-20-2019, 03:28 PM   #7
AZ Chev
AZ Chev's Avatar
I’ll take it Randy, please pm me pp info. Just to confirm, this will fit my 72 K20 with guages and auto trans?
AZ Chev is offline   Reply With Quote
Old 05-20-2019, 04:15 PM   #8
randy500
I'm sorry its sold to jimer1964.
Old 05-20-2019, 05:14 PM   #9
projectking
projectking's Avatar
I used a ‘69 harness in my ‘67 GMC and it bolted in with no issues. I did have to lengthen the wires for the wiper switch though
68 GMC C3500 Longhorn DRW
67 Chevy C10 LWB
90 Mustang Gt
90 Mustang Notchback
projectking is offline   Reply With Quote
Old 05-20-2019, 06:04 PM   #10
randy500
Did you screw it in sideways like 68 is mounted? Where the screw holes the same?
Old 05-20-2019, 07:48 PM   #11
projectking
Screw holes are the same. I did separate the half’s and move the NSS/BU wiring to be on the bottom like the OG is though.
67 Chevy C10 LWB
90 Mustang Gt
Old 05-20-2019, 08:15 PM   #12
randy500
Screw holes are the same. I did separate the half’s and move the NSS/BU wiring to be on the bottom line the OG is though.
Good info, i figured it might bolt up, think I might have even done it a very long time ago.
Old 05-20-2019, 08:30 PM   #13
projectking
Here it is
67 Chevy C10 LWB
90 Mustang Gt
