![]() Join Date: Dec 2009
Cab Sheetmetal/Between cab corners?
Does anyone Reproduce the piece of sheet-metal
between the cab corners? Here's a Picture of area below. Mine appeared to be good until I drilled the spot welds out and removed the floor-pan . I am replacing the full floor-pan so I want (must have) new sheet-metal in this area. It looks like I will have to make it. I just bought a Bead roller. So I guess I need to get busy making one. Thanks .
________________________________________________________________________________________ ____________________________________________ 84 Chevy K-20 63 Impala (my high school car) http://67-72chevytrucks.com/vboard/s...Crew Cab Build |
![]() Join Date: Dec 2014
Re: Cab Sheetmetal/Between cab corners?
I’ve never seen that area made in a patch panel but I’m sure you could find someone on the parts for sale area that has one.
I bought a nice original cab corner a while back, way easier then making a aftermarket panel fit. |
718jwh
Thanks for the advice. I will keep that as a option and post a WT B add later possibly. Right now I'm working towards making that piece. It won't be hard to make. Also it is in a spot on the truck that is not highly visible. If I could buy it would save some time. Every-time I run across a piece like this I send a e mail to A M D so it maybe some day would be Repoped.
