05-20-2019, 12:41 AM | #1 |
Idler/Pitman Arm Torque
Does Anyone Have The Torque Value For The Pitman and Idler Arm To The Cross Shaft Where The Tie Rodends Bolt To? Thanks
Posted via Mobile Device |
05-20-2019, 10:24 AM | #2 |
Re: Idler/Pitman Arm Torque
tight, then lineup the cotter pin hole
05-20-2019, 11:40 AM | #3 |
From 1970 service manual:
pitman arm to relay rod nut and idler arm to relay rod nut are both 60 ft/lb
1970 C20 Custom Camper - 350, TH350 1997 GMC Suburban 1994 Acura Integra GSR 1987 Dodge Daytona Shelby Z |
05-20-2019, 12:16 PM | #4 |
Thanks Guys. I Also Have 2 fosm Washers. 1 is 1/4 inch and 1 is 1/2 inch. Where do these go. Somewhere on the idler arm or pitman arm?
05-20-2019, 01:04 PM | #5 |
Pretty sure there is one between the pitman arm and the cross shaft. I assume the idler arm is the same way.
