Old 05-20-2019, 02:14 PM   #1
HTX86chevy
HTX86chevy's Avatar
starts but dies immediately
5.3 DBW and 4l60e into 72 c10 with Factory tank.
This is my 1st time doing an LS swap.
reworked harness myself using guide from (Brenden/Lt1swap.com)
had PCM done by Brenden also.
walbro 255 inline fuel pump
I have added grounds like crazy including 1 to PCM case
I have swapped fuel regulator 3 times and seem to be getting only 52psi on gauge
when I engage the key, I can hear the fuel pump run and stop after a few seconds. I turn the key to on and the engine cranks, starts and dies after 2-3 seconds. no sputtering or anything, just cuts off.
I don't have the OBD port wired up yet.
Any Ideas? what should be my next step?
HTX86chevy is offline   Reply With Quote
Old 05-20-2019, 03:05 PM   #2
mongocanfly
Post Whore
mongocanfly's Avatar
Re: starts but dies immediately
Is the maf hooked up?
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 05-20-2019, 03:37 PM   #3
HTX86chevy
HTX86chevy's Avatar
Maf is NOT hooked up. Does it need that to run? I don't have a MAF sensor to hook up to. do I need to go get an air box and MAF sensor and hook that up?
Update: Ran out and Pulled MAF from my sons truck. hooked it up and she fired right up and ran perfectly.
I owe you a beer, sir. Thank you so much for taking the time to reply!
Old 05-20-2019, 09:10 PM   #4
lutronjim
On my 'connect and cruise' the MAF had to mounted in the middle of at least a 12" straight tube. If I remember it wanted 4" diameter.
I initially bought a pretty chrome pipe from ebay - about 3" diameter. It ran but had a weird throttle response and continually set codes.
Might want to check when you mount yours.
lutronjim is offline   Reply With Quote
Old 05-20-2019, 09:32 PM   #5
mongocanfly
Post Whore
Haha...I might take you up on a rootbeer!..
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 05-21-2019, 11:02 AM   #6
JJ1972
Check to see if you have oil pressure sending unit wired to PCM. It will start and then die. I know from experience.
JJ1972 is offline   Reply With Quote
Old 05-21-2019, 04:19 PM   #7
bigdaddy4x4
bigdaddy4x4's Avatar
was the vats removed ? and check the grounds again
bigdaddy4x4 is offline   Reply With Quote
