05-20-2019, 10:41 PM | #1 |
Carpet Vendors?
After test fitting my carpet I noticed that the area between the kick panels was at least an inch too short. I see this has been an issue in the past. It looks like Auto Custom Carpets is the go-to in carpeting. However, it looks like they also might be a little short in this dimension according to a post or two I read.
Has anybody recently tried ACC or another brand that fits better? Personally, I'd rather it be too big all around so I could finish the final trimming. Thanks! |
05-21-2019, 12:28 AM | #2 |
Re: Carpet Vendors?
I just purchased an ACC kit in Dec and it fit just about perfect. Plenty of extra carpet at the doors and rear for trimming. At the kick panel where it is a finished edge, it fits about as perfect as you can get for aftermarket. All the molded areas were right where they should be. If I was to be super particular, I would like to see the finished edge where the brake cable passes through the firewall have a notch. If I lowered the carpet below the cable it didn't match the seat mount hump. So I chose to push it forward and will have to make my own relief cut. Minor issue IMO for an otherwise perfect fit.
05-21-2019, 01:11 AM | #3 |
Re: Carpet Vendors?
Used Acc carpet in 2 trucks. A '64 high hump and a '66 low hump. Both came up a bit short between the kick panels, but the low hump was worse. I thought maybe it was a touch off square when I laid it down as one side was more affected than the other, but when I tried squaring it up it stayed the same due to the way it hugs the center hump. Oh well, it's still a lot better than the nasty ol' shag carpet remnant that was in there when I bought it.
05-21-2019, 07:46 AM | #4 |
Moderator
Re: Carpet Vendors?
I asked ACC about the kick panels being short. They stated it's that way because GM did it that way. Did these even come with carpet new?
05-21-2019, 10:21 AM | #5 |
1965 Chevy C10, 2005 4.8L/4l60
Re: Carpet Vendors?
You can go to an upholstery shop and get the cardboard backing and make your own, Velcro works fairly well to secure it
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
05-21-2019, 01:38 PM | #6 |
Re: Carpet Vendors?
05-21-2019, 02:57 PM | #7 |
Re: Carpet Vendors?
TopFuel1966
That's what I thought as well. Thanks. |
05-21-2019, 06:39 PM | #8 |
Re: Carpet Vendors?
Yeah, after thinking about it, I'm gonna cut about an inch or two off the sides and add the required amount from the trimmed pieces to fit up to the kick panels and also add enough to fill the the little triangle-shaped nook. I'll splice like you would normally splice a typical carpet. I also have a buddy who has a heavy duty sewing machine to resew the finished edge hem.
I figure if I was gonna spend money on a new carpet I might as well try to modify this one. Nothing to lose! |
