![]() Join Date: Sep 2007
Oil dipstick location
I'm running a 5. 3 out of a 03 GMC Yukon. Installed it in my 67. Now I'm starting to put everything on and I realize now that the dipstick is blocked by the headers. Un if you have pictures of your dipstick that you used in your LS swaps with headers?
1967custom |
Post Whore
![]() ![]() Join Date: May 2015
Re: Oil dipstick location
I used the stock one ...just bent the tube to clear the headers..
The bends pretty extreme already. Should I heat it first?
1967custom |
Post Whore
I used my brake line bender...no heat....but mines better quality than the cheap ones though...
I've seen a flexible dipstick on summit...might work for you if nothing else does...not cheap though
no theyre not, I was thinking that I might have to go that route as well. ill use a bender on mine first and see what happens. thanks bud
1967custom |
I used a Camaro dipstick tube and cut down my stock truck dipstick to the right length for the shorter Camaro tube. I did it mainly for looks but it also cleared my Speed Engineering headers.
Yeaahhh, i bent mine too, no heat... mounted on the front exhaust manifold stud/nut. Ghetto but truck doesnt make me money, i just like the thumbs ups and comments...
![]() Join Date: Dec 2012
I used my stock gen 4 truck dipsticks and tubes. They cleared the headers and bolted to the original location. I will get a picture for you today. I will be there in about 1 hour.
1956 Chevy Bel Air 2 door 1956 Chevy 210 4 Door 1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD 1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E 1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD* GO ![]() |
1965 Chevy C10, 2005 4.8L/4l60
![]() Join Date: Aug 2004
I used an f-body dipstick
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
I ended up buying a Lokar dipstick. I had the same issue with my headers and this dipstick worked out perfectly. Plus it will never blow out and it locks.
Lokar X1220217 Anchor-Tighr Black Braided Stainless Steel Finish Engine Dipstick |
Here is the picture I forgot to post
