Old 05-21-2019, 09:45 PM   #1
Peanut74
71 frame question
Ok, my 67 frame was bent so I purchased a 71 donor truck for the frame. Once I started comparing the two frames I noticed some differences. Attached is a picture with four differences I found:
1- I believe is a bracket for the automatic transmission linkage
2- I have no idea
3- I believe is a helper spring but never seen one like this
4- Is this a factory rear bumper?
Can anyone confirm my assumptions. Thanks
Peanut74 is offline   Reply With Quote
Old 05-21-2019, 10:17 PM   #2
Jason Banks
Jason Banks's Avatar
Re: 71 frame question
1. Yes automatic transmission linkage
2. Looks like an exhaust hanger welded on by an exhaust shop?
3. Yes. Helper spring
4. Got me...
Jason Banks is offline   Reply With Quote
Old 05-22-2019, 02:53 AM   #3
stsalvage
Scrapper 1
stsalvage's Avatar
1967 is different One from 1968--72 1967 does not have a power steering on the frame Depends on what your options were for either truck if you had coil overs in the rear on your 1967 to leaf spring in the rear Most people in the '70s went with a leaf spring. One thing better from 1967 to 1968--72 is you can bolt a Steering box on 1971 frame The bumper looks factory If you had a 1967 3/4 ton and you got a 1971 3/4 ton you will Love the new Dana 60 slide off drums makes doing brakes easier.
stsalvage is offline   Reply With Quote
Old 05-22-2019, 07:24 AM   #4
rpmerf
rpmerf's Avatar
Going by my 70 C20.
1. Looks like the auto trans linkage I have on my truck.
2. Looks like an exhaust hanger. The exhaust should be inside the frame at this point. I am assuming this is for aftermarket exhaust that dumps in front of the rear wheels.
3. I have these helpers on my truck.
4. Not sure. I don't think my bumper has that vertical diamond plate. Could had been an option though.
1970 C20 Custom Camper - 350, TH350
1997 GMC Suburban
1994 Acura Integra GSR
1987 Dodge Daytona Shelby Z
rpmerf is offline   Reply With Quote
Old 05-22-2019, 08:25 AM   #5
Peanut74
Smile Re: 71 frame question
Thanks for the info guys. Just wanted to make sure I knew what they all were before I made any changes or removed anything.
Old 05-22-2019, 09:44 AM   #6
cebra
#4, I am not 100% sure but I believe I have seen that same bumper and it was a GM dealer add-on option.
My Daily Driver Build: http://67-72chevytrucks.com/vboard/s...d.php?t=755668
cebra is offline   Reply With Quote
