05-22-2019, 01:52 AM | #1 |
Affordable Rear Disc Brake Kit Help
Hey guys,
I'm wanting to upgrade my rear drum brakes to rear disc. I need help finding an affordable place to buy a kit. I will be wanting a kit WITH e-brake cables. Feedback appreciated! |
05-22-2019, 07:44 AM | #2 |
Moderator
Re: Affordable Rear Disc Brake Kit Help
On a 68? or what?
05-22-2019, 08:53 AM | #3 |
1965 Chevy C10, 2005 4.8L/4l60
Check out Captn Fabs solution, you source calipers and he has the mounts and knows which rotor to use
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
05-22-2019, 10:11 AM | #4 |
67-72 parts collector,…
Captainfab has a wide variety of rear disc kits and brackets.
Look in the signature of his posts, for links to those threads. http://67-72chevytrucks.com/vboard/s...d.php?t=339280 You also never said what year rearend. 10 bolt or 12 bolt 5-lug or 6-lug
05-22-2019, 10:23 AM | #5 |
Never Ending Projects
Yep, I have used CaptianFab brackets on two different trucks. Since I converted both to 5 lug, it uses the PBR style Camaro rear brake calipers, which has a good e-brake system, unlike a lot of other companies who use the Cadillac calipers which has a horrible e-brake system. I haven't done a 6 lug rear end so not sure which calipers they use.
. 1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
05-22-2019, 11:11 AM | #6 |
Moderator
The Cadillac/Trans Am e brake is fine, IF you use it every time. It relies on regular use to stay adjusted. Since most people didn't do that, they got a bad rep. I have a couple of them at my place. I also have the CaptainFab style OEM on my 96 Impala SS.
05-23-2019, 12:31 AM | #7 |
Thanks for the help everyone! I appreciate it.
I guess I did leave out some details of my build: Truck: 66' Longbed Rear End: 12 bolt (6 lug) |
05-24-2019, 12:51 AM | #8 |
60-66 Nut
I make 2 different rear disc conversion bracket sets for the 6 lug.
http://www.67-72chevytrucks.com/vboa...d.php?t=494411 http://www.67-72chevytrucks.com/vboa...d.php?t=637489
05-27-2019, 01:33 AM | #9 |
Hey guys,
Got a question for the group... I've been researching different kits and parts. And it seems that I do not know the center bore diameter of my axel. I guess I would need to take off my rim and measure it. Does anyone know what diameter it is off hand? Thanks!! |
