![]() Join Date: Aug 2016
Will it work?
I have plans to use the later model rallye wheels with baby moon caps for a low buck wheel option for a while. I am thinking of using double sided 3m tape or command strips to hold them on. I am not above trying a welded tab or another means of securing them. Any ideas? Think the tape will hold without flinging the caps to the wind? Test wheel pic attached
72 C10 lwb fleetside aka Big Rhonda. Still plugging away. Build thread: http://67-72chevytrucks.com/vboard/s...42#post8247142 |
Re: Will it work?
I’ve seen people use clips like these.
https://www.alfabb.com/bb/forums/giu...ing-clips.html |
![]() Join Date: Sep 2007
Re: Will it work?
the double sided tape will fall off on your first run. heat will kill them. youre best off tapping them clips onto the wheels. not hard at all
1967custom |
Re: Will it work?
Thanks fellas. I see a lot of different clips. Anyone made it work? Which clips did you use?
Re: Will it work?
I'm interested to find out as well, I'd like to have another set of wheels to change up the look every now and then.
Brian 1972 C10, "Loyd", LWB to SWB, 5.3, L83/6L80e, 4:11 Tru Trac, Air Ride, VA, DD, 20" Coys, 4 wheel disc, A quick LS swap turned into a 6 year frame off resto-mod. |
Re: Will it work?
look up the clips for older chevy vehicles using baby moons. like on the artillery wheels. those will be the correct clips.
1967custom |
Re: Will it work?
Thanks, I will give it a go in the next few weeks
