Old 05-24-2019, 07:29 AM   #1
hooverfish
hooverfish's Avatar
Turn Signal Question
Turn signals on my 72 are too sensitive. Left signal switches OFF if I move the wheel only an inch or two.
When using the right signal, its better, but it too switches off if there is just a little movement in the wheel.
Do you think I just need an adjustment or will I need to replace parts ?
I'm going to replace the steering wheel soon and only want to pull the wheel once and fix the turn signal issue while I'm in there.
I've been reading past posts on replacing turn signal switch but want to figure out what I need before I start. This is non tilt column.
Larry
84 Chevy SWB, "Roy", dark blue OG paint, 5.7 LS1, 4L60, Vintage Air, 96k miles.
"It's a sorry man who can't find his wife a good job"
hooverfish is offline   Reply With Quote
Old 05-24-2019, 08:52 AM   #2
bowtie72
bowtie72's Avatar
Re: Turn Signal Question
You may not know what parts you need until you remove the wheel. There are two springs that hit a cam when turning the wheel that cancels the signal. The springs could be broken or the cam could be broken. Does your horn work? This cam also connects the horn. The male piece that sticks up thru the wheel locates the cam to the right position. I have seen these broken also. Good luck it isn’t a hard job at all. It helps to have a puller.
1968 SWB "Little White Truck"
1972 LWB LS 4l80 "Plain Jane!!"
bowtie72 is offline   Reply With Quote
Old 05-24-2019, 10:10 AM   #3
Wrenchbender Ret
If your strg. wheel is not centered it will cause this. Drive the truck & mark the position of the wheel when you are going straight down the road. Line up the marks & pull the wheel. Put it on in the straight ahead position. The front end alignment should be correct when doing this.
George
Wrenchbender Ret is offline   Reply With Quote
Old 05-24-2019, 10:33 AM   #4
Ironangel
Ironangel's Avatar
Location: Falls City, Nebraska "100 Miles From Nowhere"
Number 27 on page 183 for the switch assembly and number 10 on page 129 for the cancelling cam at LMC. http://www.lmctruck.com/icatalog/cb/full.aspx?Page=129 Might find a board vender that will beat their pricing...?
Michael of the clan Hill,
"Two Seventy Two's"
71 1-ton Dually 350 4-Speed
71 C/50 Grain Truck, 350 Split-Axle 4-Speed
02 3/4 ton Express
14 Indian Chief Vintage
1952 Ford 8N, "Only Ford Allowed On The Property"
"Be American, Buy American"
Ironangel is offline   Reply With Quote
Old 05-24-2019, 11:40 PM   #5
Cintidude04
I just installed a new turnsignal switch from GMCPaul's. Does the same thing, Not sure if there's an adjustment for it. I'll keep an eye on this thread as well.
1972 Chevy C10 Longbed Fleetside 350ci
Cintidude04 is offline   Reply With Quote
Old 05-25-2019, 10:29 AM   #6
hooverfish
hooverfish's Avatar
Thanks for the good info. Yes the horn works. Gonna do the free rent for a puller at local parts store.
George
Think my wheel is centered but I will check to make sure, thank you!
Thanks for the parts info, good to see what may be needed. Trying to avoid buying parts until I'm sure what's needed. I appreciate your help.
Thanks for posting that, makes me think TS switch is not the culprit.
Hopefully someone else who has solved this problem will post. And I will update this thread when I know something.
Larry
Old 05-25-2019, 10:38 AM   #7
hooverfish
hooverfish's Avatar
George
Wrenchbender Ret
When I mark the wheel position, what's the best way to do this? Measure (example 3/4" from top dead center on column to top dead center on wheel) then remove wheel rotate 3/4" and reinstall ?
Larry
Old 05-25-2019, 12:03 PM   #8
woodz1972
https://www.youtube.com/watch?v=L0yyZIsNiag
This may help
woodz1972 is offline   Reply With Quote
Old 05-25-2019, 12:20 PM   #9
Wrenchbender Ret
Originally Posted by hooverfish View Post
Wrenchbender Ret
When driving straight down the road put a chalk mark on the streering wheel hub to the t/s coller. Pull into the shop & line up the marks. Remove the wheel & put it on in the straight ahead position.
George
Old 05-25-2019, 09:30 PM   #10
hooverfish
hooverfish's Avatar
Originally Posted by woodz1972 View Post
Woodz1972, thanks for the link to the video.
I put the horn button in the 10:30 position as shown in the video, but it doesn't seem to help.
George
My steering wheel was off by about 1/16 of a turn. Corrected it nice and straight now,
but it doesn't help with the turn signals cancelling prematurely.
Still have the same problem.
The good news is the new steering wheel (beautiful early take-off original)
looks terrific.
Larry
