Old 05-24-2019, 11:56 AM   #1
jnickell41
2007 TBSS E67 TCC Wiring
I have read some conflicting information on Gen IV TCC wiring and have a question about my specific situation.
Engine and transmission are from a 2007 TBSS with E67 ECM.
I have included a picture of the ECM pinout as well as part of the wiring diagram I have been looking at.
The ECM pinout shows "TCC Brake Switch/Cruise Control Release Signal" on C1 Pin 2 Purple wire
The wiring diagram shows C1 Pin 2 as "TCC Brake SW" going to "Anti-Lock Brake System" I believe the CHMSL Supply voltage on C1 Pin 7 is used to disengage the cruise control
I have yet to start the truck, but I currently have C1 Pin 2 (TCC Brake SW) to hot with brakes off and C1 Pin 7 to hot with brakes on (CHMST Supply Voltage).
Having the TCC switch wired to hot while brakes are off seems opposite from some of the info I have read on Gen IV computers.
Any input would be appreciated.
jnickell41 is offline   Reply With Quote
Old 05-24-2019, 12:17 PM   #2
ls1nova71
ls1nova71's Avatar
Re: 2007 TBSS E67 TCC Wiring
C1 pin 2 is only for ABS/traction control and cruise control, you don't need it in a swap. You only need C1 pin 7 which is hot with brakes applied.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 05-24-2019, 01:44 PM   #3
jnickell41
Thanks Nova.
I am attempting to utilize the cruise control function with this setup.
As you stated, and some additional searching revealed, C1 Pin 2 is utilized by the ECM for cruise to function.
I will leave the wiring as is for now and report on function once I have the truck running.
Thanks,
John
