Old 05-24-2019, 06:52 PM   #1
elorenzof
No Limit Rack and Pinion Install 1970 c10
I want to purchase the No Limit Rack and Pinion kit for my 1970 c10. Looking at their install instructions it states that the engine mounts must be in the last two of the three factory holes on the frame. My engine sits in the front two of the three so i need to move it back. I need some advise please. I understand there is only two mounting holes on each side of the block (small block engine). What motor mounts allow you to move mounts back and still use the same holes on the block while using the last two of the three holes on the frame? Or maybe im not reading it correct. Does the whole engine need to be moved back? will that make me have to shorten my driveline? Anything else some one can think of or someone who has done this no limits R&P install to chime in?
elorenzof is offline   Reply With Quote
Old 05-30-2019, 12:07 PM   #2
elorenzof
Re: No Limit Rack and Pinion Install 1970 c10
Anybody?
Old 05-30-2019, 12:27 PM   #3
RodnRudy
RodnRudy's Avatar
If you use the rear two holes on top of the frame I'm pretty sure you have to use 6 cyl engine stands. Hopefully some one will correct me if I'm wrong. I would call No Limit and ask them to clarify their instructions before ordering the rack kit.
Phil
"Money is only a tool to create and achieve what you want most in life"
PayPal: rodnrudy@comcast.net
RodnRudy is offline   Reply With Quote
