Old 05-25-2019, 02:28 AM   #1
1972BackInBlackC10
1972BackInBlackC10's Avatar
c notch question
getting ready to install the CPP bolt in c notch and it requires you to remove the two rivets for the coil spring mounting plate. I removed the coil spring mounting plates so id have more room to clean the frame and I was wondering if anyone has installed their notch with out the coil spring mounting plates, would it be safe to leave mine out or should I put them back in when I install the notch?
1972BackInBlackC10 is offline   Reply With Quote
Old 05-25-2019, 09:40 AM   #2
RodnRudy
RodnRudy's Avatar
Re: c notch question
You need to reinstall that part. It gives structural rigidity to the frame, helps to keep it from twisting. I'm not an engineer but that's my take on it.
Phil
"Money is only a tool to create and achieve what you want most in life"
PayPal: rodnrudy@comcast.net
RodnRudy is offline   Reply With Quote
