Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1960-1966 Chevrolet & GMC Pickups Parts Board
Old 05-25-2019, 10:17 AM   #1
Joe P
Active Member
Wanted to Buy 66 K20 Original Rear Spring Blocks
Hi there! New to the site, working on a 66 K20 that was trash and slowly bringing her back. I want to put the original rear spring blocks in - My truck had PO blocks that were, well, lets be kind and say "not original". I am in CT. Anyone have a pair to sell?
Joe P is offline   Reply With Quote
Old 05-25-2019, 11:12 AM   #2
Harlowhead1972
Re: Wanted to Buy 66 K20 Original Rear Spring Blocks
Hi Joe. I believe I still have a clean set from a 1966 GMC K20. I will post pics later today. Thanks, Harlow
Harlowhead1972 is offline   Reply With Quote
Old 05-25-2019, 11:35 AM   #3
Joe P
Active Member
Thanks Harlow! Looking forward to the photos!
Old 05-25-2019, 01:21 PM   #4
Harlowhead1972
Hi Joe. Sorry, it looks like I only have the front blocks left. I am working on getting another 64-66 vintage K20. I will let you know if I get it and if the rear blocks are intact. Thanks, Harlow
Old 05-25-2019, 02:37 PM   #5
Joe P
Active Member
Thanks for looking, Harlow. I have the front blocks in good shape, just need the rears. Appreciate your courtesy!
Old 06-05-2019, 07:11 PM   #6
jdl71
jdl71's Avatar
Are you wanting the lift blocks?
Psalm 23
64 C10
66 K20
jdl71 is offline   Reply With Quote
Old 06-10-2019, 03:45 PM   #7
Joe P
Active Member
Yes still looking for a pair, thank you!
Old 06-10-2019, 06:15 PM   #8
jdl71
jdl71's Avatar
I didn't realize some came with front blocks also.
Psalm 23
64 C10
66 K20
Old 06-10-2019, 06:40 PM   #9
Joe P
Active Member
I'm not sure if they did - My truck does not have lift blocks up front, but does have a couple of blocks on top of the springs, more like "Bump Stops"
Old 06-10-2019, 06:42 PM   #10
Joe P
Active Member
I am looking for original rear blocks. This is what I have today...
Old 06-10-2019, 07:01 PM   #11
jdl71
jdl71's Avatar
My rear lift blocks look much different
Psalm 23
64 C10
66 K20
Old 06-10-2019, 08:03 PM   #12
Joe P
Active Member
Yes, these are not original. The PO added them. I have not been able to find originals so I may just reassemble with these blocks and change them out when an original set comes along.
Old 06-27-2019, 11:48 PM   #13
Joe P
Active Member
Still looking...
Old 07-02-2019, 10:04 AM   #14
SmirchIs#1
Originally Posted by Joe P View Post
Still looking...
Im not real familiar with the 60-66 group of trucks.I have a 61 K 20 for parts.I looked at the rear mounts.They look like a combination lift block and lower shock mount all in one.If this sounds correct,I'll take pics.
SmirchIs#1 is offline   Reply With Quote
Old 07-02-2019, 10:50 AM   #15
Joe P
Active Member
Thank you yes. It may be correct. This is the block that goes between the bottom of the spring and the axle perch. The photos that I have seen show what looks to be similar to an I think it incorporates a bump stop too. Thank you!
Old 07-02-2019, 08:23 PM   #16
Joe P
Active Member
Here are a few photos of what I think are original blocks
Old 07-03-2019, 12:12 AM   #17
Dsuper5
Dsuper5's Avatar
Up for grabs:
Dsuper5 is offline   Reply With Quote
Old 07-03-2019, 06:50 AM   #18
Joe P
Active Member
That’s it! How do I make them mine?
Old 07-03-2019, 09:14 AM   #19
Dsuper5
Dsuper5's Avatar
Well lets see, my Garage needs a new roof....my tires are bald....!
PM me with your contact info and i ship them out!
Cheers Eddy
Old 07-04-2019, 09:25 AM   #20
Joe P
Active Member
Cheers Eddy
Thanks Eddy. I left a PM...
Old 07-05-2019, 12:32 AM   #21
1971 GMC SHORTY
1971 GMC SHORTY's Avatar
Wow When I got My 1 st 4x4 66 GMC I Use to Think What Were Thet Thinking With Those Strange Blocks
1966 GMC K25 V6 351E Original Utility Truck
2000 C3500 Hot Rod Utility Truck
2003 ROAD KING 100th 124ci 6 Speed
145CI M/P Pro Street FXR
2002 FXDP
2007 2500HD DURAMAX. DD
Studio Teamsters / Mechanic
Retired GM Master Tech 20 Years
Retired Ford Tech 15 Years
1971 GMC SHORTY is offline   Reply With Quote
Old 07-05-2019, 07:07 AM   #22
Joe P
Active Member
Yes, they are strange for sure. I guess that a plain rectangular block is substantially heavier. Perhaps the designers wanted to reduce the weight a little. Anyway I prefer the original ones because they are "original".
Old 07-05-2019, 07:35 AM   #23
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
I have a pair without the shock mount on them.
Old 07-05-2019, 11:22 AM   #24
Joe P
Active Member
Thanks but i think dSuper5 has a pair for me, just waiting to hear. Looking at photos, I don't think these blocks have a shock mount, but do have a bump stop. It appears that 3/4 ton trucks have the lower shock mount welded to the axle housing. It appears the one ton trucks had no rear shocks at all. I am not sure on this but both of my Eaton one ton H072 axles don't have the shock tabs - One is a 65 and the other is a 66...
66k20
