Old 05-26-2019, 01:57 PM   #1
WOLFMANmike
WOLFMANmike's Avatar
2 questions for you guys here
# 1 when i got my truck from the PO it was already changed to a Automatic 350 from a stick so he cut the manual trans cross member out to fit the 350 trans if i want to put in a stick shift again does that mean i have to get another manual trans cross member and have it welded back in or can i just do the swap? and next question is can you put Linseed oil on a rattle can paint? or will it ruin the paint? asking here because i have tried to google it and cant find anything on it i know you guys use it on patina trucks only thing i can find about it is on wood lol thanks again for all your help
WOLFMANmike is offline   Reply With Quote
Old 05-26-2019, 03:43 PM   #2
heavy71chevy
heavy71chevy's Avatar
Re: 2 questions for you guys here
As for the crossmember I'd just find used or build one.not to involved if you really look at it.The linseed will be fine but it should be nice and cured paint tho so it can't lift it
"Dixie Destroyer"
71 C10 LWB Fleet
Future Blown Prostreet Monster
heavy71chevy is offline   Reply With Quote
Old 05-26-2019, 03:53 PM   #3
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
The auto should have the crossmember at the tail, most modern std shift use rear crossmembers also.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 05-26-2019, 04:22 PM   #4
WOLFMANmike
Ok cool thanks. So do you think that if I put in a stick 4 speed it will get some better mpg ?than it does with the auto 350 ?
Old 05-26-2019, 05:14 PM   #5
jayoldschool
Moderator
If you short shift it, maybe 1mpg better. Maybe not. If you want better, you'll need a trans with OD.
jayoldschool is offline   Reply With Quote
Old 05-26-2019, 06:15 PM   #6
Clyde65
Clyde65's Avatar
You need to find out what gear ratio you have in the rearend.
If you have 4.10:1 then you should raise it to 3.73.
I have that ratio and a 4l60e, I get real good mileage.
Clyde65
Rebuild of Clyde
support our troops!
