Old 05-26-2019, 07:50 PM   #1
spitfire980
spitfire980's Avatar
LS1 Alternator bracket help
Hi Guys
Iv got a bit of an issue, Id like to relocate my alternator to the top and to the side however none of the brackets I see would work with my power steering.
As you can see from these sample pics, my PS reseviour is the see through plastic type however all the brackets that iv seen have the built in black ones
Example:
Is there a difference between these 2 styles or is it all the same?
Any help or tips would be appreciated!
spitfire980 is offline   Reply With Quote
Old 05-26-2019, 08:34 PM   #2
mongocanfly
Post Whore
mongocanfly's Avatar
Re: LS1 Alternator bracket help
looks like to run alt up high youd have to change p.s.p. and brackets as well...just a guess though
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 05-26-2019, 09:01 PM   #3
ls1nova71
ls1nova71's Avatar
That last pic is of a vette system, its totally different from the GTO. You would have to change everything, including the crank pulley and watt pump to use that. What kind of car is it in? Looks like the low mount would work.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 05-27-2019, 03:04 AM   #4
spitfire980
Its in a 67 C10, as you can see, the reservoir is a completely separate unit instead of the single piece black one
Single piece PS
My PS looks like this
Old 05-27-2019, 04:58 AM   #5
mongocanfly
Post Whore
is the last truck pic yours? purple truck?...if the engine fits ,whats wrong with leaving alt and pump as is?
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 05-27-2019, 05:41 AM   #6
spitfire980
Yep, thats my C10
Build thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=731589
The reason I want to move it up is because its uncomfortably close to the frame rail...moving it up would make things easier
Old 05-27-2019, 12:36 PM   #7
mongocanfly
Post Whore
Could you just notch the frame rail?...how close is it?
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 05-27-2019, 05:52 PM   #8
spitfire980
Unfortunately not, In my country, any play/notching/welding to the frame makes the car not registrable
Its about a finger to finger and a half
