Old 05-26-2019, 09:14 PM   #1
Funstuie
Another “what is this” post from me
Hey all
Quick one. Doing some upgrades and clean up on the 76 c19 today I discovered that this canister is not connected to anything. The hose gonna to the engine is just hanging there not connected and the hose going down is split open next to the radiator. So with no fear of looking stupid my question is, what is it?
Funstuie is offline   Reply With Quote
Old 05-26-2019, 09:19 PM   #2
jocko
jocko's Avatar
Re: Another “what is this” post from me
fuel vapor canister - part of emissions system.
Old 05-26-2019, 09:20 PM   #3
Funstuie
fuel vapor canister
Thanks. Is it an issue not being connected to anything?
Old 05-26-2019, 09:24 PM   #4
TKCR
TKCR's Avatar
No, a lot of people take them out anyways. Cleans up the engine room. Odd place for it though. It usually mounted low, in the front of the engine room.
Old 05-27-2019, 12:23 AM   #5
franken
Those are used to make fuel vapor get sucked into the engine and burned. The system uses a nonvented gas cap so one way or another, the tank is being vented if the system isn't working. It's pretty simple to make it work and has a purpose.
franken is online now   Reply With Quote
Old 05-27-2019, 08:13 AM   #6
Dead Parrot
If you opt to remove that, you will need to make sure your gas tank(s) get venting. Simply plugging the line to the tank will most likely create fuel flow problems. Plus plan on getting used to a gas smell as instead of being captured by the canister, the vent fumes will simply smell as they are released.
This thread has the no canister system: http://67-72chevytrucks.com/vboard/s...d.php?t=786794
Dead Parrot is offline   Reply With Quote
Old 05-27-2019, 09:10 AM   #7
100%Chevy
That's where they are mounted on 6 cylinder trucks.Mine's in the same place.
mike.
100%Chevy is offline   Reply With Quote
Old 05-27-2019, 10:04 AM   #8
WorkinLonghorn
WorkinLonghorn's Avatar
Good luck trying to register your truck in San Francisco with smog devices removed.
Just hook it up with good vacuum lines.
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, stereo speakers, 2nd owner, Work-Truck supreme.
WorkinLonghorn is offline   Reply With Quote
Old 05-28-2019, 11:18 AM   #9
gmachinz
Fuel vapor is a great “additive” to the combustion process-anything to enrich the flammability rate of your mixture is a good thing-the more complete the burn, the more (to a point) you can extend the lean limits to pick up slightly more fuel economy.
gmachinz is offline   Reply With Quote
Old 05-28-2019, 04:34 PM   #10
demian5
demian5's Avatar
x2. You must be new to CA.
Make sure you hook it up to the right port on the carb...
"Work hard, use your vacation days."
1970 C15 GMC Long Bed
1986 C20 Scottsdale
1983 K2500 Sierra Classic Suburban 6.2
Instagram: C10sofOC
demian5 is offline   Reply With Quote
Old 05-30-2019, 02:15 AM   #11
Greasey Harley
Greasey Harley's Avatar
That is the best evap canister you could have.
Easiest one to hook up, and no extra crap.
Run the fuel tank vent(s) to one side, plug the other side into the big port on the front of your carb and VIOLA! No more stinky gas fumes.
Good stuff.
I would move it to the core support just in front of the steering box.
Greasey Harley is offline   Reply With Quote
Old 05-30-2019, 02:34 AM   #12
Funstuie
This truck was smoged and registered in this condition. I haven’t removed anything it’s still in the engine bay just not connected to anything.
It won’t require a new smog till 2020. Maybe the law will be updated to exempt later 70’s vehicles (one can hope).
I can’t find where on the carb it should be connected though.
Old 05-30-2019, 08:11 PM   #13
Greasey Harley
How 'bout a photograph of that-there carburetor?
Old 05-30-2019, 08:50 PM   #14
Funstuie
Like this
Old 05-30-2019, 08:51 PM   #15
Funstuie
Stupid photos won’t rotate
Old 05-30-2019, 10:30 PM   #16
Greasey Harley
I would plug it in to that open port on the drivers side front, down by the idle screw.
I think that is a vent. (Somebody please correct me if I'm wrong)
Either way, It should live happily there.
Old 05-30-2019, 10:39 PM   #17
Funstuie
This one?
Old 05-30-2019, 10:51 PM   #18
Greasey Harley
just to the left of that circle
Old 05-30-2019, 10:54 PM   #19
Funstuie
Perfect. I see it now. Thanks.
Old 05-30-2019, 10:55 PM   #20
Greasey Harley
Happy to help
