Old 05-27-2019, 06:26 AM   #1
Afirehawk1
66 c10 steering column rebuild help needed
I took apart the 3 speed automatic column (column shift) and now im not sure how it all goes back together. Any detail photos out there?
Afirehawk1 is offline   Reply With Quote
Old 05-27-2019, 07:34 AM   #2
The Rocknrod
Moderator
The Rocknrod's Avatar
Re: 66 c10 steering column rebuild help needed
Column parts breakdown on post #4 -http://67-72chevytrucks.com/vboard/showthread.php?t=667819
Also - http://67-72chevytrucks.com/vboard/s...5&postcount=17
Old 05-27-2019, 07:58 AM   #3
damnyankee36
damnyankee36's Avatar
Manual or auto?
damnyankee36 is offline   Reply With Quote
Old 05-27-2019, 01:16 PM   #4
Afirehawk1
Originally Posted by damnyankee36 View Post
Manual or auto?
3 spd auto on the column
Old 05-27-2019, 01:18 PM   #5
Afirehawk1
Can u resend the first link?
Did not copy correctly
Old 05-27-2019, 01:35 PM   #6
damnyankee36
That's what I thought I remembered. Here are pics of my 2-speed. There's a possibility that they are different but I would imagine only dimensionally and that would probably be just the shifter detent at the bottom end.
Old 05-27-2019, 01:36 PM   #7
damnyankee36
Old 05-27-2019, 01:38 PM   #8
damnyankee36
Old 05-27-2019, 01:45 PM   #9
Afirehawk1
I think i see the 1st piece i have
Ideas on the other 2?
Old 05-27-2019, 02:06 PM   #10
damnyankee36
Nope. Figures there would be a difference!
Old 05-28-2019, 02:07 PM   #11
JFBerg713
In damnyankee’s pictures. The first and second pic shows the swivel bolt that the shift linkage rod fits into. Does anyone know how to take that bolt off? There is a tension pin on it but I removed that and still dont see a way to pull that bolt off. I assume i can cut it but that seems like a pain in the A.
John B
JFBerg713 is offline   Reply With Quote
Old 05-28-2019, 06:55 PM   #12
damnyankee36
Here's an exploded view of the that part. Mine didn't have any kind of pin. It just fell apart after removing the C clip.
Old 09-26-2019, 03:48 PM   #13
Afirehawk1
well apparently i do not know how to put this thing back together.
Is there a new column on the market that will accept the stock steering wheel, automatic 3 speed, column shift.
the problem with the one i had rebuilt is it does not have the neutral safety switch which i really need on this truck.
Any nice rebuilt ones that serves this purpose out there?
thanks Keith
Old 09-27-2019, 09:08 AM   #14
Afirehawk1
if i can get my column put back together, can i use this to accomplish my backup lights to work?
Old 09-27-2019, 11:10 AM   #15
Wrenchbender Ret
You can use that switch for backup lights or n/s switch but not both.
Wrenchbender Ret is offline   Reply With Quote
Old 09-27-2019, 12:43 PM   #16
Afirehawk1
I called lokar
I have to use their linkage assembly it appears
This is getting Difficult
Old 09-27-2019, 01:38 PM   #17
damnyankee36
Your attachments won't open for me for some reason.
You weren't able to weld a tab on the inner tube like I described in your other post to engage a switch?
http://67-72chevytrucks.com/vboard/s...4&postcount=12
Old 09-27-2019, 02:38 PM   #18
vince1
https://www.amazon.com/s?i=automotiv...dp_lf_ladp_1_4
Amazon shows this Standard Motor Products NS5 neutral/back up switch as correct for a 66. It is my experience that those type switches do both the back up light and neutral lock out functions, with two pairs of wires going to the two different sets of terminals on the switch. Other #'s are NS14 and NS15 but probably not good for your application.
vince1 is offline   Reply With Quote
Old 09-27-2019, 02:53 PM   #19
damnyankee36
We should almost merge these two threads...
http://67-72chevytrucks.com/vboard/s...+on+the+Column
Old 09-27-2019, 03:48 PM   #20
Afirehawk1
I tried
It didn’t hold so not sure what to do
Old 09-27-2019, 04:09 PM   #21
damnyankee36
Keep trying. You don't have a good enough weld/penetration. A correct weld will be more than strong enough to hold the tab in position.
Old 09-27-2019, 05:34 PM   #22
Afirehawk1
Will do!
Old 04-23-2020, 10:05 AM   #23
Afirehawk1
Update. after reading everyone's posts, i came up with an idea on making my own tab for the reverse switch. instead of welding it in place, i did this.
i created a small tab and shaped to accept the reverse switch and the curvature of the column. after a few trial/erros/and fitment, then i used 3M Body Panel Adhesive to glue it in place. i tell you what, that worked like a champ and was easier than i thought it would be.. switch works great and the tab isnt going anywhere. that stuff is hard as a rock.
thanks for the ideas and tech support.
Keith
Old 04-27-2020, 09:54 AM   #24
Afirehawk1
i reassembled my column. is anything missing before i install the steering wheel?
also working on the column harness using the American Auto Wiring Classic Update. My harness mimics the 63 with the exception of the tan/green, mine is black. do i follow the 63 or 66 wiring diagram.??
