Old 11-29-2003, 02:13 AM   #1
HatGuy
HatGuy's Avatar
Unhappy Dumb thing to do
I left my hatch open and tried to drive out of
the parking garage. The handle cought on a
light cover on the celling and snaped it off flush.
Two problems:
1. Can't get it open.
2. Need to find a new handle with key.
Any help will be Appreciated !
Joe Peters the HatGuy
72' K5 Highlander
My Daily Driver
http://www.pbhats.com/BLAZER/index.html
HatGuy is offline   Reply With Quote
Old 11-29-2003, 04:28 AM   #2
Alexis
Member since 2000
Alexis's Avatar
i've been told if i wanted a new handle to go to one of those truck camper places and buy the handle assembly. just a thought.
Alexis is offline   Reply With Quote
Old 11-29-2003, 05:50 AM   #3
badpeanut
Not a bad nut after all..
badpeanut's Avatar
Buy a garage door T-handle from a hardware store for about $8, cut the shaft to length, and move over your internal mechanism. Cosmetically it will differ and you will lose the flapper door in the key hole, but I've done this to my Blazer and it works. I know of no better source at this time.
Good luck!
badpeanut is offline   Reply With Quote
Old 11-29-2003, 07:04 AM   #4
'68OrangeSunshine
'68OrangeSunshine's Avatar
BTDT
To open the hatch try pulling on the relay rods from inside with a needlenose vicegrips til it clicks, then do the other side.
Golden State sells a replacement handle, but it's not OEM and requires some modification.
'68OrangeSunshine is online now   Reply With Quote
Old 11-29-2003, 03:22 PM   #5
HatGuy
HatGuy's Avatar
Thanks everybody!
how about a used one out there
72' K5 Highlander
My Daily Driver
Old 11-29-2003, 11:55 PM   #6
K5KRAZIE
If I recall correctly NAPA carries the handle with the key too
TRUCKS
'72 K5
'06 mega dually
K5KRAZIE is offline   Reply With Quote
