05-27-2019, 06:56 PM | #1 |
Cab Rust Areas
Hello all - posted a few pictures of my cab where rust is located on my 1971 Chevy C20 that I purchased from San Diego 6 years ago. Who said SoCal trucks are rust free? LOL!
I have a cracked windshield so I hesitate to replace it because of the rust areas in the attached photos. I don't know if the rot is in the windshield seal area and if the windshield perimeter is weakened from the inside rust shown. Looking for comments from individuals who repaired similar rust area on the cab. Thank you! |
05-27-2019, 07:39 PM | #2 |
Cab Rust Areas
05-27-2019, 08:07 PM | #3 |
Re: Cab Rust Areas
Wish I could help you with the rust but I can't. However, as a native NTer I just have to say hello. Give them my best regards at Galassi's and Platters.
05-27-2019, 08:47 PM | #4 |
Re: Cab Rust Areas
Howdy to Tristan!
05-27-2019, 09:39 PM | #5 |
Re: Cab Rust Areas
Sorry to see that- looks pretty bad. I would guess the windshield flange is really weak
05-27-2019, 10:21 PM | #6 |
Roadtrip!
Re: Cab Rust Areas
I would think either a roof replacement, or cab replacement depending on the rest of the truck. I think you will be opening a can of worms if you remove the windshield.
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
05-27-2019, 11:10 PM | #7 |
Re: Cab Rust Areas
If yours is like mine the seal area is fine. The only way to know for sure is to pull the windshield out and while it is out repair the rotted areas. You might wire brush the inside areas and see just how far the rot goes before pulling the windshield.
05-28-2019, 01:27 AM | #8 |
Re: Cab Rust Areas
That dont look pretty. Pretty sure you are gonna open a can of worms when you pull out the old windshield. There are a lot of ways to "fix" this. Probably the right way would be to remove the outer truck roof and replace. Then patch in the inner with new metal. I have seen others treat the rust and apply fiberglass filler. Obviously not a long term or structural fix though. Either way, good luck!
1967 C10 Suburban 454/TH400/3.07's An Average Joe and His 'Burb: http://67-72chevytrucks.com/vboard/s...d.php?t=775843 Last edited by LockDoc; 05-28-2019 at 11:16 AM. |
05-28-2019, 04:53 PM | #9 |
Re: Cab Rust Areas
There's a reason it was painted without pulling the windshield . if the inner and outer cab look that bad the pilars and rockers are gone also . Your looking at cab replacement it's just not worth repairing all that rust and it's going to be a lot worse when you pull that windshield considering only 1/2 of what's bad is reproduced sheet metal . Sell it and buy another . Never buy a truck with shiny paint on the rubber windshield gaskets .
1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
