Old 11-29-2003, 02:36 AM   #1
Broken_down?
dip stick !@#$^%&*(
wtf every time I check the oil the dam dip stick pipe/neck that goes into the side of the block pops out! !@#$^%&*() Do you guys have any idea how annoying that is!!! does anyone have a fix for this? PLZZZZ!!!! HELP!!!!
Rich
Don't get upset when she marks her territory in the driveway.
WHY DO THEY CALL THEM JUNKYARDS ANYWAY??? I LIKE TO THINK OF IT AS A TREASURE HUNTING MISSION
Broken_down? is offline   Reply With Quote
Old 11-29-2003, 02:49 AM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Do you have the old block with the dip stick on the drivers side, or a later engine with the passenger side dip stick?
Old 11-29-2003, 03:42 AM   #3
oldyeller
Captain CAAAVVVMMMAAANNN!
oldyeller's Avatar
you could take a punch and swell out the tip that goes in to the block, that would give it some friction. similar to what you get with a press fit. Then put a coat of sealant around it to stop any potential leak.... Or just go pick up a chrome dipstick and install it. The new one should fit tighter.....
72 LWB Fleetside C10 Custom 350/350
97 GMC Yukon 4X4 SLT
Anna, Texas
check out the project old yeller
oldyeller is offline   Reply With Quote
Old 11-29-2003, 03:50 AM   #4
DanoDMano
Pronounced "Pew-al-up"
DanoDMano's Avatar
It is a pain!! And I have to feed my dipstick all the way
in or it dont go!!!
Classic GM Trucks of Washington Club Member
1970 FS chevy,350/350, Edelbrock cam and intake. Holley 650 carb,HEI,AT,Tangier Orange, 18's,
Power Locks,
Truck Photos
DanoDMano is offline   Reply With Quote
Old 11-29-2003, 01:35 PM   #5
67Fleetsidedream
Wiseass secured himself a BAN
67Fleetsidedream's Avatar
I would do what oldyeller said. Easy fix........
67Fleetsidedream is offline   Reply With Quote
Old 11-29-2003, 02:14 PM   #6
dtlilly
dtlilly's Avatar
Does your dipstick not have a flange with a hole to be able to use a head or exhaust bolt to keep it stationary?
dtlilly is offline   Reply With Quote
Old 11-29-2003, 02:22 PM   #7
Hotrod70C10
Low & Slow
Hotrod70C10's Avatar
I just ran a bead of silicone around the tube and stuck it back in the hole. It hasn't moved since...
70' C-10 LWB Fleetside
4.5/6 drop
Hotrod70C10 is offline   Reply With Quote
Old 11-29-2003, 02:24 PM   #8
Broken_down?
Longhorn Man it is on the drivers side..
dtlilly The only thing that remotley helps to hold it in place is the heat shield of the mainfolds. and never works.
Do you guys think that just JB weld will hold it ok??
I woudl put a crome one it but problem is my engine is not cromed out and it In my opinion kinda funky. But when I put the original 327 back in I will do that though.
Thanks for the opinions.
Rich
Old 11-29-2003, 02:27 PM   #9
junkyardjohn
junkyardjohn's Avatar
KNURL THE O-D OF THE TUBE THAT GOES INTO YOUR BLOCK WITH A CENTER PUNCH, OR TAP IT OUT OF ROUND WITH A HAMMER. THEN SMEAR A COAT OF SILICONE SEALANT ON THIS DIA., & PLACE A 5/16" BOLT IN THE OTHER END, & TAP ON THE BOLT WITH A HAMMER (TO KEEP FROM DEFORMING THE END), DRIVING THE TUBE INTO THE BLOCK. JOHN
junkyardjohn
69 1 TON TOW TRUCK //
84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES//
LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS)
DON'T RENT U-HAUL
ALWAYS TELL THE TRUTH
IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST
junkyardjohn is offline   Reply With Quote
Old 11-29-2003, 08:18 PM   #10
cableguy0
dont jb weld that into the block it will become a nightmare if it ever needs to come out. like everyone else said swell the end that goes into the block with a punch put a little bit silicone on it and it shouldnt go nowhere
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
