Old 05-28-2019, 12:42 PM   #1
MDPotter
MDPotter's Avatar
Gen IV & Vintage Air
I've been thinking about this setup on my dad's 64 for a few weeks am not convinced it's right or maybe I just don't understand it. It's a Gen IV 5.3 with a Dewitts radiator/dual Spal fan setup. The radiator/fan setup came with relays and a harness and we used the trigger wires from the PCM to control them and my understanding is that the PCM turns on the first fan when the coolant reaches somewhere around 210 and the second comes on when it hits 230 or so. I don't know if these fans have a low/high function or not, they've only ran at what seems to be full blast.
We took the truck to a local shop to have them charge the Vintage Air system as they have experience with them. We had previously installed the trinary switch, but the shop told us we need to install a 3rd relay to control the fan so it comes on whenever the compressor is engaged. The other day, it was in the 70s and sitting idling, the compressor would engage for a few seconds at a time, so the fan was cycling every few seconds. Is that the correct operation? It just seems like the fan is going to get worn out with that much cycling and at this point I don't even know what the trinary switch does.
1964 Chevy C10 - Gen IV 5.3 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=768632
1968 GMC C15 - Gen III 6.0 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=772047
1969 Chevy C10 - Restoration http://67-72chevytrucks.com/vboard/s...d.php?t=809184
1978 Chevy Scottsdale K20
1993 Chevy C1500 - 5.3/T56 swapped
2008 Silverado Duramax
MDPotter is offline   Reply With Quote
Old 05-29-2019, 06:54 PM   #2
sprint_9
sprint_9's Avatar
Re: Gen IV & Vintage Air
That doesnt sound right.
I posted some info in this thread : http://67-72chevytrucks.com/vboard/s...d.php?t=776599
As far as I know that info is correct, but I have not tested it myself yet. I can confirm that within HPtuners there is a table for AC system pressures and fan set points. I am hoping that the switch talked about in the above post relays that info to the ECM and it runs the fans according to the pressure relayed by that switch.
sprint_9 is offline   Reply With Quote
Old 05-29-2019, 08:02 PM   #3
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
I’m not sure but I believe the gen IV compressors are different and don’t work the best, the Gen III is what I run with my Old Air Products AC.
I run a trinary and have the pcm turn on the one fan at 190, then the other at 210 or when AC is turned on. Hope this helps.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 05-30-2019, 12:54 AM   #4
First c10
First c10's Avatar
I think a trinary switch gives you 12+ when calling for fans so you will need a relay for a negative trigger for the cooling fans. Is this correct?
I think even with a trinary switch, the fans cycle when the ac compressor is engaged as soon as the pressure gets to the trinary fan set point and when it drops the fans turn off.
1956 Chevy Bel Air 2 door
1956 Chevy 210 4 Door
1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD
1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E
1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD*
GO GO!!!
First c10 is offline   Reply With Quote
Old 05-30-2019, 03:01 AM   #5
ls1nova71
ls1nova71's Avatar
A trinary switch is just that, a switch. Whether it provides power or ground depends on how its wired up. If you put power to one side of it, then when it turns on it will supply power, same goes for if you put one side to ground then the other side will be grounded when closed.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
