Old 05-29-2019, 10:35 AM   #1
GMCNUT
GMCNUT's Avatar
Ignition woes - switch needed?
I don't know why, but when its cold or started for the first time, my 72 blazer ignition has started hanging when I hit the key and the starter will turn over and over and over a thousand times unless the motor starts or I disco the battery. When hot, its started deciding not to crank at all - flip the switch and nothing happens like its totally disconnected from power. After it cools down, seems to start fine. Assumed at first this was a starter solenoid issue, so I replaced that with a brand new one only to see it act the very same. So turned my attention to the ignition switch and replaced it with a same switch spare I had laying around from a junk yard truck, and it is still doing the same thing. So I assume the junkyard ignition switch was as bad as the one I swapped it out with? New solenoid? Can't be the starter itself I would't think because it waits for the ignition to be turned on to make the solenoid jump out - the solenoid would work regardless of the starter working and thats not occurring so it has to be the switch itself - right?
So, assuming all of you agree the switch must be as bad as the one I removed, Ebay shows about 10 different ignition switches and each seller claims their switch is correct for 67-72 - part numbers I see are:
1116695, 1116704, 1116688, 1116711 and on and on. Does anyone really know what GM part # the ignition switch is supposed to be for a 72 Blazer w/ normal 350 V8 / Automatic / CST / etc?
My Projects and Toys - All 100% Stock
1972 CST "Highlander" Blazer - 350 auto, PS, PB, A/C, Tilt, Tach, AM/FM & Positraction
1966 Chevy SWB Fleetside BBW Custom Cab, #'s matching 327 V8 & Powerglide, factory deluxe heat, PS, PB, Tinted Glass, sway bar
1961 Chevy SWB Fleetside BBW Custom Cab #'s matching 283 V8 & Powerglide w/ uber-rare Cool-Pack A/C, factory PB, deluxe heat, Clock
1961 GMC K1000 4x4 SWB w/ BBW, Custom Cab and numbers matching 305D V6 engine & 4 spd
1960 GMC SWB Fleetside BBW Custom Cab #'s matching 305A V6 & Hydramatic, factory PB, Clock, Tach, Compass, Hood Jet
1959 Chevy SWB Fleetside BBW Custom Cab w/ rare stainless bed trim, #'s matching 283 V8 & Hydramatic, Deluxe Heat, radio, spotlight
1958 Chevy Cameo #'s matching 283 V8 & Hydramatic, radio, window washers, Factory PB
1958 GMC BBW SWB Fleetside Custom Cab, #'s matching 336 V8 Hydramatic, Factory PS, PB, Clock, RSD, Deluxe Heat & Hood Jet
1957 GMC Suburban Pickup (GMC's Cameo) #'s matching 347 V8 Hydramatic, uber-rare vacuum ashtray, Factory PS, PB, Clock, RSD, Hood Jet
1956 Chevy 3800 1 ton w/ rare 9 ft stepside bed, factory 265 V8 w/ Hydramatic, factory PB, Custom Cab, deluxe heat, spotlight and hood jet.
GMCNUT is offline   Reply With Quote
