05-29-2019, 12:14 PM | #1 |
Front clip engine electrical
Under my previous thread -Befuddled with engine problem it came down to replacing the engine. As there was other work I wanted to do at the same time, I pulled the from clip.
The engine is now ready to go back in and I want it running and the other work done before I re-install the front clip. So my question is do I need anything plugged back into the firewall connecter from the front clip to get it running? Are there any other electrical items I need to be aware of besides the starter circuit and 12 volts to the HEI distributor ? |
05-29-2019, 12:31 PM | #2 |
Re: Front clip engine electrical
Which motor did you get?
Do you need to break it in? That might decide what needs hooked up. |
05-29-2019, 12:45 PM | #3 |
05-29-2019, 01:01 PM | #4 |
Post Whore
Make sure the charging system is isolated. Do you have electric guages?
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
05-29-2019, 01:04 PM | #5 |
Are you gonna hook up your rad?
You likely still need some higher rpm for 10 minutes to splash oil everywhere. |
05-29-2019, 01:19 PM | #6 |
05-30-2019, 10:50 AM | #7 |
05-31-2019, 09:22 AM | #8 | |
Post Whore
Personally I would rather have everything assembled up correctly before start up. That allows me to test everything to be sure it works before jumping into the engine break in. Just my opinion which has no value outside of my head.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 Last edited by HO455; 05-31-2019 at 09:30 AM. |
