Old 05-29-2019, 06:00 PM   #1
LuckyDSquared
Three-speed to auto column swap w/ power steering on a ‘62
Hey all, I’m fitting my rig with power steering. It’s a ‘62 and I used Captain Fabs brackets to get my gear box on. Now I’m looking at my columns. Im confused as to the intermediate shafts and the ends of the columns. The white one is my three-speed original column and the black one was advertised as 67-72 auto column. I even bought what was advertised as a 67-72 intermediate shaft. However, the column and the intermediate shaft for the 67-72 have different fittings. The column is splined while the intermediate looks like it wants a pin to lock into the column.
Can anybody explain what I have here and what I need to get my wheel to the gearbox?
LuckyDSquared is offline   Reply With Quote
Old 05-29-2019, 11:38 PM   #2
slepysal
slepysal's Avatar
Re: Three-speed to auto column swap w/ power steering on a ‘62
You need an intermediate shaft that will attach to your splines on the 67-72 column and "rag joint" to attach the new column to the gear box.
You can cut the shaft below the "bell" and use adapter to attach it
https://www.summitracing.com/search/...shaft-couplers
Hope this helps
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes.
"Over, Around or through it... "
slepysal is offline   Reply With Quote
