05-29-2019, 09:04 PM | #1 |
Electrical Connector Question
This connector is up behind the glove box on my '68.
is this for a glove box light? Three wires, Yellow Green and Brown. It is partially melted..
1968 C20 Fleetside 396 4sp PS PB AC CST . https://www.youtube.com/watch?v=RWK8GgWD4uA |
05-29-2019, 09:11 PM | #2 |
Re: Electrical Connector Question
radio I believe
05-29-2019, 09:33 PM | #3 |
Post Whore
Is your truck an A/C truck?
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
05-29-2019, 09:43 PM | #4 |
Yes, AC truck, the connector is "L" shaped, the radio was missing when I bought the truck and there is no original flat radio connector.
05-29-2019, 09:51 PM | #5 |
Post Whore
I'm not 100% sure but that may be the lead to the blower control relay on an A/C truck. I am pretty sure it isn't the radio lead. I rewired my non-A/C truck and reinstalled the factory radio in my Burban. So the radio wiring I am familiar with the A/C not so much.
Do a search for A/C blower control relay or wiring. Good Luck.
05-29-2019, 09:55 PM | #6 |
Old member
It looks like the AC relay that mounts on the passenger side on the duct work under the dash.
05-30-2019, 12:31 AM | #7 |
I will look again tomorrow, I couldn't find where it attaches..
05-30-2019, 09:28 PM | #8 |
OK, so I found out that the brown wire was added by Bubba the Previous Owner.
The brown wire was stuffed in the connector and poked through the firewall and attached to the blower motor hot lead, Why?? I don't know.. brown wire removed. all plugs in position on the AC relay, so I am still looking for where the Green and Yellow connector went originally..
05-30-2019, 10:16 PM | #9 |
From the service manual. Dark green and yellow wire to the compressor clutch switch. I don't know what the DBL/WS means added to the 16DG. The wire should not be both dark green and dark blue with a white stripe. They labeled the wire more plainly in the 1969 manual, just 14DG.
05-30-2019, 10:28 PM | #10 |
Hmmm, Now I have to locate where the compressor clutch switch is, .. Mine might be missing..
05-30-2019, 10:43 PM | #11 |
In the bottom of the 2 pictures above, shown behind the A/C box under the dash. Somebody may be able to post an actual picture of it, instead of just the service manual page. Here is the service manual link: http://67-72chevytrucks.com/vboard/s...d.php?t=558016
05-30-2019, 10:57 PM | #12 |
Thanks very much, I know where to search now..
05-31-2019, 02:33 PM | #13 |
Thanks to Stocker, now I know what part to order and where it goes..
http://67-72chevytrucks.com/vboard/s...d.php?t=787771 .
05-31-2019, 07:02 PM | #14 |
20' Daredevil (Ret)
Sorry I didn't post in this thread earlier. I was confused by your brown wire and didn't see your post #8 last night. No telling why it was stuffed in there -- maybe as a way to power up the A/C compressor instead of replacing a bad switch? Anyway, glad you figured it out!
