Big Block 4x4 motor mounts
I'm toying with the idea of swapping out my 250 six in my 72 4x4 in favor of either a 396 or 454 that I've got access to. What motor mounts would I need? Not sure what to use since the 4x4s didn't originaly come with a big block.
Thanks, Josh
72Chevy swb 4x4 71GMC swb 2x4 |
Small block motor mounts is what you will need to use.
You move them forward one hole on the frame. The motor mount on the right will move forward one hole ok. The left motor mount will need a hole drilled in the frame for the forward hole while the mount has the rear mount hole in the existing forward hole in that side. Sounds confusing.
Washington State 1967 Chevy C10 LWB Rodstoration In Progress. 1972 K20 Cheyenne Super |
imdarren,
Nope... you didn't confuse me. Thanks for the info! ![]() ![]() Josh
Post Whore
![]() Join Date: Feb 2000
Here's what I did http://www.myoldtruck.com/modules.ph...&pid=12&page=2
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
Thanks Jack very informative.
Dave 1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap 1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?) "A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome". "If it doesn't fit force it...If it breaks then it needed to be replaced anyway!" |
