air redirection/blocking material
My A/C condenser is mounted 2 to 3 inches in front of my radiator on the outside of the core support where the radiator is on the inside of the core support. My fans draw air through the rad well enough but from there the air doesn't really get pulled through the condenser as good as I would like. There's a 2 inch gap along the top and on the driver side between condenser and core support and a 4 inch gap on the passenger side. I've considered several types of material for covering these gaps and am currently thinking on these... Summit racing neoprene rubber sheets: https://www.summitracing.com/tx/part...9512/overview/ This is 1/4 inch thick 12"x12" panel of rubber that I can cut. I figure I can zip-tie or even screw these onto the condenser edges and let them get sucked into place by the fans to cover the gaps with the core support. What have you guys used for sealing up radiator/core support/condenser air channels? Thanks, -klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi 07 335 sport turbo 6sp 94 Trans Am GT LT1 6sp posi -- sold after 22yrs 99 540 sport V8 6sp -- sold 73 240z L24 4sp -- given to friend 68 C10 step 350/350 3.73 open -- sold |
| Bookmarks |
