05-31-2019, 01:46 PM | #1 |
WTB 1971 under hood wiring and relays
Looking for these pictured relays and wiring harness that goes with it. They are mounted just above where the parking brake cable goes through the firewall.
72 Cheyenne Super swb. Factory 402/400,tach,posi,AM/FM, A/C. Adding cruise, 8-track 72 Cheyenne Super swb. 350/350 A/C, bucket seats 72 Cheyenne swb. Factory 402/400, tilt, posi, A/C 72 Cheyenne Super K-10. 350/4 spd., posi. 72 Suburban 350/350 tilt, tach, AM/FM, A/C, luggage rack 72 GMC Sierra lwb. 350/350, A/C. medium green/olive interior |
05-31-2019, 04:16 PM | #2 |
Re: WTB 1971 under hood wiring and relays
What are the relays used for?
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Power windows Power Locks Sniper EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear |
05-31-2019, 04:21 PM | #3 |
Good question - I'm not sure? Most all of my trucks are '72s and they have similar relays under the dash by the fuse panel. I've seen these external relays on '71 trucks before so I'm pretty sure the set up is from the factory. Neither under hood wiring harness looked like it had connectors that would go to these relays.
05-31-2019, 05:14 PM | #4 |
im not sure but i think 1 of them is the tcs (transmission controlled spark relay)
most of the trucks that i have seen have had those wires cut off the harness at the relay.
i survived cancer and kidney stones, but my kids are killing me. |
05-31-2019, 09:08 PM | #5 |
My 70 had the TCS solenoid near the heater box
06-01-2019, 01:56 PM | #6 |
It’s 2 relays and a harness for the TSC. If you want good ones they are available new from several of the catalogs. They are not needed and just an early attempt at pollution control. I would hazard a guess most people just remove them or they have been hacked up. In order to work you also need the pieces that are on the transmission, a unit on the intake manifold and the temp sensor/sender in the head. Unless you’re restoring, I’d just remove the remaining items. The sensor in the head is in a water jacket so drain the block before removing and installing a pile plug.
1971 Custom/10 - 350/3 speed, Orange/White roof |
06-01-2019, 04:54 PM | #7 | |
06-01-2019, 05:34 PM | #8 |
I can’t be sure the 2 relays on mine were any good, but I have them both and I’ll be glad to send them your way free of charge. They are just sitting in my parts box right now.
06-01-2019, 05:47 PM | #9 |
That's awesome! I'll PM ya.
06-02-2019, 09:10 AM | #10 |
I dont know what it is for either but our 71 has it. Cant be transmission related as ours has a 3 on the tree. Factory. And a 307. No power brakes and no power steering. Unmolested. Cant get a better picture right now in paint jail.
