Old 06-01-2019, 01:47 PM   #1
Pina
1970 C20 bench seat question
I have a 70 C 20. The stock bench has seen better days, bad foam and broken springs.
I found a bench seat from a 75 C10. Will this work for my truck? Are there any modifications that will need to be done to make it fit?
Pina is offline   Reply With Quote
Old 06-01-2019, 10:04 PM   #2
kingsolver72
10/30/19
kingsolver72's Avatar
Re: 1970 C20 bench seat question
I’m thinking that it won’t bolt up correctly. You can always measure the seat frames to verify.
kingsolver72 is offline   Reply With Quote
Old 06-02-2019, 12:05 AM   #3
Astro-Balls
Astro-Balls's Avatar
Get a New foam Kit and Seat Upholstery it will be good as new.
1968 C20 Fleetside 396 4sp PS PB AC CST
https://www.youtube.com/watch?v=RWK8GgWD4uA
Astro-Balls is offline   Reply With Quote
Old 06-02-2019, 11:34 AM   #4
leddzepp
Moderator
leddzepp's Avatar
It won’t bolt right up. Seat frames and mounting tracks are different. I’m sure you could “make it work” by drilling new holes and/or modifying mounts. Most any older seat you find will have busted springs on the sides which cause you to lean outwards and be uncomfortable. Repair the one you have is what I’d do.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
leddzepp is offline   Reply With Quote
Old 06-03-2019, 09:54 AM   #5
Pina
Thanks for the advice. Any idea on where to source springs?
Old 06-03-2019, 10:13 PM   #6
Astro-Balls
A local Auto Upholstery shop can fix your springs for you.
bench seat, c20
