06-01-2019, 03:35 PM | #1 |
brake pressure switch, what connector?
Hey guys! I just installed a new pressure switch but can't seem to find a connector that fits over the prongs. I tried a 10-12 butt connecotr but it is to small. Do they make a 10-8? Is there a custom made 2 prong connector for these things?
06-01-2019, 03:52 PM | #2 |
Post Whore
Re: brake pressure switch, what connector?
what you need to look for is bullet wire connectors...not sure what size your pins are
06-01-2019, 03:58 PM | #3 |
Yeah I went to Autozone and Advance Auto But couldn't find them. I thought maybe a butt connecotr trimmed down would work, but the largest i could find was 10-12 guage. They are just a little to small. UGH!
06-01-2019, 04:00 PM | #4 |
Post Whore
might check at a electrical supply store...bullet connectors are meant to snap into the groove on the pin...
06-01-2019, 08:26 PM | #5 |
here is what you need. Dorman HELP! 85845 90 Degree Amazon or Ebay
06-02-2019, 01:05 AM | #6 |
A pair of those Dorman connectors would cost about the same as a small pack of the blue female bullet connectors from O'Rielly's, Autozone or Ace and would be a lot less subject to moisture.
A lot of guy call those bullet connectors Ford connectors as you find them all over 70's, 80's and 90's Fords if not later.
06-02-2019, 05:22 PM | #7 |
I just went out to my parts bin and pushed this blue butt connector onto a Ford-style prong - perfect secure snap fit.
If it were me, I would strip the blue insulator off and use heat shrink tubing to seal it and give it a finished appearance.
1951 Chevy Panel Truck Last edited by MiraclePieCo; 06-02-2019 at 05:33 PM. |
06-02-2019, 07:17 PM | #8 |
Theres no way I can get a blue butt connector onto my prongs. I believe blue is what 18 gauge? I tried a 10-12 yellow and it was to tight. Hmmmmmmm
06-07-2019, 01:46 AM | #9 |
It's a catastrophic success.
Have tried these?
06-07-2019, 06:47 AM | #10 |
If you have a hobby shop near by, bullet connectors are often used for batteries in RC planes and cars.
06-07-2019, 10:58 AM | #11 |
This is correct. This is what you need.
Amazon is really a blessing and a curse. All the shops that would have kept these a decade ago are probably out of business now. As someone mentioned, you need an Electronics Distributor (mostly out of business). An electrical distributor would be a close second, and would likey have them as well. If you can get these guys to sell to you, they probably have them. Rumsey Electric Company Authorized Distributor Details » 2459 Baglyos Cir Bethlehem, Pennsylvania 18020-8025 Phone: 610-832-900018.1 mi 24/7 Emergency: 800-404-6080 I know they are a little far from you. There might be other electrical distributors closer, but these guys would likely have these, based on the other product lines they keep. |
06-10-2019, 03:38 PM | #12 |
Thanks guys! Got it taken care of. Actualy Jegs and NAPA both have connectors with rubber bootys on them made specificaly for these brake switches. I found out about them after I used the female bullet conector.
06-10-2019, 04:16 PM | #13 |
06-10-2019, 04:48 PM | #14 |
Actualy Jegs has the whole kit........https://www.jegs.com/i/JEGS/555/63070K1/10002/-1
I found just the connectors at NAPA hanging on one of their electrical racks. |
06-10-2019, 08:57 PM | #15 |
Very cool. Thank you.
