Just curious If anyone has takin a 67-72 body and put it on a '73-87 4x4 frame. What changes were made to make it fit? I ask this because I have an oppertunity to get a free frame with 350 engine, and want to know if it will work. Thanks
Jason ![]()
2003 Yamaha Blaster for sale : $1900 OBO Last edited by 67_396; 11-29-2003 at 02:35 PM. |
PROJECT 7DEUCE
![]() Join Date: Dec 2002
I believe mudder 67 has done this swap?? Could be wrong..
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
![]() Join Date: Feb 2001
If you can weld and cut some its no big deal. I have pics of all the mounts and some helpful tips if ya wanna pm me your email addy.
Seeker of the big and bad
I've done three of these swaps and they look good.First,turn the rear cab mounts to the out side of thr frame and move the mount hole about 1 nch inward taward the drive lineYou my need to trim alittle off the mount because our cabs tapper down and they hit the edgeof the mount.You'll need to remove the saddle tanks but they won't fit our cabs anyway.Then from the front mount you need to go 1inch out and one inch forward of the original mount hole for the front of the cab.You will need to make a body lift for the front off the cab or raise the mount.you then need to weld a 6x6 pad,not very thick about 1/16 to the top of the leaf spring,radiator bracket on the front.Here you'll need a 4 inch lift spacer to the radiator support,don't forget to add in your bushing thickness's.The back off the cab will sit flush(about 3/4 to 1 inch above the frame.Then you will need to move your rear spring hangers forward 1 1/4 inches,BUT ONLY FOR A LONGBED!, short bed will line up.you will need to place 2 inch blocks under the bed to match the body line with the cab.The easyiest way I've found to get the bodyline right is the mount the bed and the rear of the cab then lift the front end up till the body line matches and then build the corrected mounts you need for the front of the cab and radiator support.I hope this helps and not hinders.Remember you now have somewhat of a body lift so a 6 inch spring lift will clear 36 in tires no brob.
71 3/4 ton 4x4,665hp 454. 67 GMC 1 ton towtruck 68 chevy LB 4x4 64 chevy LB custom 57 Bel-air 2d station wagon |
With a 1972 Chevy Custom-10 Long bed w/350cid th350, (under-construction). Progress on truck so far (follow link): http://67-72chevytrucks.com/vboard/s...ad.php?t=51051 and stage 2 http://67-72chevytrucks.com/vboard/s...ad.php?t=58132 ~ ![]() ![]() Last edited by SEVEND2; 10-05-2007 at 04:54 AM. |
Robert Olson Transport
![]() Join Date: Oct 2002
hey mudder lol hold them thoughts im thinking it may be my next project!! lol
